Brakes for rear
Old Dec 26, 2018 | 01:31 PM
89transam500hp's Avatar
Brakes for rear
does any one have ford 9 inch moser with dual rear calibers on each side that will fit a 15 inch rim
Old Jan 4, 2019 | 04:36 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Brakes for rear
Wilwood sells them, I have them for mine
Old Jan 4, 2019 | 12:50 PM
Tony V's Avatar
Car: 88 Camaro
Engine: 383
Axle/Gears: Moser 9 inch/4.11 TruTrac
Re: Brakes for rear
https://www.jegs.com/i/Wilwood/950/140-7140-DR/10002/-1
Old Jan 4, 2019 | 01:13 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Brakes for rear
Depending on what ends are on the 9”, strange makes a dual caliper kit too
is this for some sort of footbrake class?
Old Feb 3, 2019 | 11:36 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Brakes for rear
they should make the ends to take the PBR rear disk as well..thats anybody making the 9"..using the PBR rear disk..= bolt on parts..and Wilwood makes the kits to replace the GM parts..the E brakes are a bit diff.
iroc stangs
Brakes
Mar 30, 2019 09:15 AM
dhirocz
Feb 22, 2004 09:27 AM
MrDude_1
Feb 20, 2004 10:18 PM
chekbaka
Nov 21, 2003 07:14 AM
RedFirebird
Jul 9, 2002 04:48 AM
