Need help identifying a proportion valve
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I need some help identifying a proportion valve. I pulled it from a 91 rs with rear discs, but the rear that was in the car was 26 spline, so Im assuming the rear was swapped in. Im not sure how to tell if this is a disc valve or drum. Or what year range it fits.
Any help would be appreciated. Thanks!
Re: Need help identifying a proportion valve
That stamp on the side that says MB. You can dig a bit and find the last time this topic came up and I posted a bunch of the codes. I dn't have time to check my notes at the moment but I'm pretty sure MB is a drum prop valve.
https://www.thirdgen.org/forums/brak...ml#post6282866
Check it out. It's half way down page one of the brake forum.
Car: '89 Firebird
Engine: 7.0L
Drum brakes.
Here's the most informative thread on this site ever made about the topic that nobody even knows exists.
https://www.thirdgen.org/forums/brak...ng-torque.html
Car: 88 IROC
Thanks. Guess I was searching too narrow when I used the entire code. Got in too much of a rush.
Yep drum brakes. Not what I was hoping for, but its what I assumed once I discovered the rear was swapped in and not from that car.
Car: '89 Firebird
Engine: 7.0L
It doesn't matter if it was for a drum. All you do is change the spring.
If you don't want it then I'll send you a few dollars for it just because I'm curious to see the parts that are inside.
Car: 88 IROC
Right, but if you were going to sell it, which was my plan, the disc ones usually fetch a much better price.
3rdgenmaro
Mar 11, 2010 02:15 PM
