Motive Power Bleeder
Old Jul 9, 2019 | 06:25 AM
ResIpsa's Avatar
Car: 1987 Formula 350
Engine: TPI 383 Stroker
Let me preface this post by saying that I’m a fairly new member on this forum I only purchased my 1987 Formula in April 2019. Prior to that (and currently) I was road racing and instructing in my Nissan 370Z.
With the 370z traditional brake bleeding never results in a hard pedal. That’s why the Motive Power Bleeder is the rule and not the exception in those circles.
The motive power bleeder works by pressurizing and filling the master cylinder brake reservoir with brake fluid. You only have to fill up the motive with brake fluid, pump up the hand pump to pressurize the canister to about 15 pounds, and then it’s as simple as breaking loose the bleeder on each caliper to bleed your brakes. You get a perfect bleed every time.
I was a little surprised when I did a search for the motive on this forum and found almost no mention of it save for the occasional post excoriating it. I felt like members were really missing out on a really good tool and I needed to rectify this situation. So I decided to try it on my new formula.
That’s when I discovered why there must be so much suspicion for the motive. Unlike my 370Z or most any new model vehicle there is no dedicated adapter to attach to the brake reservoir cap.
A quick telephone call to motive and they told me that I needed to use their universal adapter model number 1115. This adapter is a essentially a 4 1/4 x 8 3/4 aluminum plate with a rubberized backing to seal on the master cylinder brake reservoir. It comes with a set of metal hooks chains and wingnuts which are purportedly used to seal the adapter to the top of the brake reservoir.
Now I understand the distain for the motive in this community. I’ve been using this unit for nearly 10 years (albeit with the dedicated 370Z brake reservoir adapter) and still I was having trouble trying to get a seal on the master cylinder reservoir. Without a good seal you can pump and pump on the canister and nothing happens or worse you get a little bit of pressure which then quickly bleeds off before you can actually break open the bleeder valves on the caliper. Very frustrating ...
I can only imagine someone who is using this for the first time and I understand wanting to punt the little canister out of the garage.
However, all is not lost! I suggest you take the chains, hooks, and wing nuts and toss them in the trash or in your spare parts bin. Then grab some of your C clamps (or go to Harbor freight and buy their deep 5 inch C clamp) and use those to seal the cap. Voila!
Trust me, once you get up to speed with using the motive power bleeder you’ll never go back. You can bleed the brakes on any car (assuming you have the correct adapter) in seconds without the need for a second hand. And you’ll get a complete bleed that you simply cannot get with traditional foot pumping. When you push the brake pedal, you’ll be amazed at how hard it is (I apologize for the double entendre).
Old Jul 9, 2019 | 08:52 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Re: Motive Power Bleeder
I first used a professional brake Pressure Bleeder working in an auto repair shop, in the late 70's. Even then, the "Universal" type adapters, in the OP's photo, often leaked and made a mess. And that was when the MC reservoir was cast iron and you could clamp the adapter down hard, w/o worrying about breaking a plastic reservoir.
Fast forward, about 15 years ago, I bought the Motive system and most of the adapters, All except the "universal" one pictured work fine and give a through bleed! The adapter Motive sold me for my Two, 1996 Chev Impala SS's and 1995 Buick Roadmaster (B Bodies) , would NOT fit, because it was too thick to clear the firewall "Lip". Motive milled the adapter down to clear, but it still leaked. When I told them I believed it was because the Motive installed rubber gasket was too firm, to seal a plastic reservoir, they said they would "Get back to me". I never heard from Motive again and never got the Motive to work, on my B-Body GM cars.
WHEN they work correctly, pressure bleeders are great!
Old Jul 9, 2019 | 11:32 AM
ResIpsa's Avatar
As an experiment, I pressurized my Motive last night before I went to bed.The adapter that you see in the picture held 10 pounds of pressure overnight.
Old Jul 9, 2019 | 11:47 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
You can use the bleeder from the far end too, at the caliper. I think the reason it isn't suggested very often is that it's not really necessary with the design of the brake systems. There is no ABS system, and there really isn't much place for air to get trapped. I bench bled my master and prop valve and then assembled. I have a very firm pedal. I think part of the problem is people pumping the pedal when trying to bleed brakes. When you pump you can aerate the fluid. Just need to put pressure on the pedal and then open/close, release, repeat for a good bleed. :shrug:
Old Jul 9, 2019 | 04:23 PM
ResIpsa's Avatar
The Motive doesn’t work from the caliper. It only blows it does not suck.
And trust me, I don’t expect everyone on this forum to run out and buy the mystery voodoo brake machine. Especially with the consensus that it doesn’t even work and even if it did it’s unnecessary.
Just leave this post for the new member, who like me, just happens to have one and wants to know if they can use it to bleed their new third gen.
Old Jul 9, 2019 | 06:09 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Yes, I know it "blows, not suck", you can still use it at the caliper, you just need another container
Old Jul 9, 2019 | 10:27 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I've never used one of these things. Does it end up topping off (over filling) the reservoir?
Bleeding a T56 transmission hydraulics is a serious PIA, and it needs to be done fairly often if you have long tube headers.. Can the unit make a good seal to the stock clutch fluid reservoir?
Old Jul 10, 2019 | 05:09 AM
ResIpsa's Avatar
I have never had a problem with it overfilling the reservoir. Usually, I find that when you break the seal on the canister it sucks up the remaining fluid back into it. Then you simply pour in the brake fluid from the canister until you’re at the right level.
As to the clutch master cylinder reservoir I never use the motive for that. I suppose you could with the right cap or adapter, but I find using a mighty vac attached to the bleeder screw as a better solution.
Old Jul 10, 2019 | 05:32 AM
ResIpsa's Avatar
This Motive sucks...
Old Jul 10, 2019 | 08:10 AM
OrangeBird's Avatar
Car: 1989 Firebird
Originally Posted by ResIpsa
....... I find using a mighty vac attached to the bleeder screw as a better solution.
I find the mighty vac a better solution for ALL bleeding activities , be it clutch or brake work . The pressurized motive seems a complete waste of time for our cars since it has no dedicated master cylinder cover . If the manufacturer can't be bothered to make it actually work on my car , why oh why should I waste my time/money trying to make some ill fitting POS work when the mighty vac works perfectly ?
Bottom line = If someone wants to get a good "one person" brake bleed done on a third gen , skip the motive and go mighty vac instead
Old Jul 10, 2019 | 08:14 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Forget it, you obviously don't understand.
Old Jul 10, 2019 | 12:40 PM
ResIpsa's Avatar
Just so were all on board, I am not a troll sent by Motive to hawk a product. Yes I also have a Mighty Vac but the front bleeder location on my 1987 Formula does not provide good access to slip on a vacuum tube over the bleeder. Instead, I have to use the wonky right angle rubber bleeder adapter which never seals... (there I go...) I mean whichI cannot everget to seal while getting a wrench on the bleeder with one hand while pumping the mighty vac feverishly with the other hand to get a vacuum. All the while there is never any good place (unless you have three hands) to hold the little collection bottle which usually ends up popping open and spilling on the floor. And even if everything works perfectly you only have a brief period of suction and the collection bottle holds a tiny amount of old fluid.
With that said, I have used the Motive to bleed the brakes on my Formula. I used the 1115 universal adapter held on to the reservoir with 3 c-clamps. It took me all of 2 minutes to get a good seal. I tested the canister and it held 10 LBS of pressure for more than 10 hours. I bled my brakes in under 1 minute (if anyone reading this has a Motive and wants some tips on getting a good seal just pm me).
How about we just agree to disagree?
Old Jul 10, 2019 | 01:21 PM
Drew's Avatar
The Mighty-Vac is garbage. Useless on the average thirdgen. The bleeders don't seal in the calipers, air sucks right past the threads so you never really get a good pull. Then you've got those rubber adapters that don't fit the bleeders.
The pressure bleeders are a good idea, but the design of the master cylinder in our cars doesn't lend itself to the method. Our caps barely seal under the best conditions. The shop manual shows using the flat adapter and straps to make it seal.
Really though, bench bleed the master, get a second set of limbs to run the pedal and give them the 30 second crash course in following directions, works every other time.
Old Jul 10, 2019 | 02:24 PM
ResIpsa's Avatar
Drew:
I figured out how to get a great seal and it was easy. I really am not kidding about this.
The trick is to ditch the chains. They suck (unlike the Motive)!
Use C-Clamps! Take a look at my picture.
Old Jul 10, 2019 | 02:56 PM
Drew's Avatar
Excellent workaround, I applaud your problem solving ingenuity! I was mostly getting at how the GM service manual recommends this kind of power bleeding, for the benefit of the naysayers. I'd love to be able to do it that way, and have it work, but for now the willing helper has been my solution. I may have to try the power bleeder again sometime.
Another potential work around is a 4th gen master cylinder with a more common screw on cap. But then that opens up the "how do I convert to a 4th gen master cylinder" questions.
Old Jul 10, 2019 | 03:19 PM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
[QUOTE=Drew;6313469
Another potential work around is a 4th gen master cylinder with a more common screw on cap. But then that opens up the "how do I convert to a 4th gen master cylinder" questions. [/QUOTE]
i agree, this works great, if you combine it with the 4th gen pedals and booster
i recently did this on my current swap project in my 88 camaro and the motive bleeder worked great with this total 4th gen set up and the brakes work great (LS1 front / LT1 rear) with great pedal
Old Jul 10, 2019 | 05:38 PM
OrangeBird's Avatar
Car: 1989 Firebird
My workaround for the vacuum leaking past the bleeder threads is to slip a small O ring over the bleeder and slide it down the threads till it forms a seal between the threads and the caliper . I loosen the bleeder , give the O ring a little push against the caliper , and with vacuum applied it seals fine . I get a great bleed every time (the O ring trick won't work unless your bleeders and calipers/wheel cylinders are clean) and have not yet encountered any fitment issues with the rubber adapters .
Old Jul 10, 2019 | 07:53 PM
ResIpsa's Avatar
As someone who does not like using the mighty vac to bleed brakes I was appreciative of Drew supporting my position. But...
I think the absolute statements of which there can be no debate are probably not that helpful.
If orangebird has found a way to make the mighty vac more effective then that’s something that might be valuable to some member on the forum trying to bleed his brakes solo.
I don’t know what the point would be for me to attack him because I ( in my learned opinion ) know better and I know he’s lying to everyone on this forum.
I hope this forum can be better than that.
Kumbaya my lord...kumbaya...
Old Jul 10, 2019 | 09:25 PM
Drew's Avatar
All anyone can do is share their experience. The Mighty-Vac might work for someone else. My experience with it was that it was only really useful for things like testing EGR valves or other vacuum actuators. After trying different things, and contorting under the car multiple times, fighting with trying to get it to pull a vacuum without air leaking in, blah blah blah... It went in the trash.
In retrospect I probably should have held onto it, but honestly after 10 years in the tool box, and only getting used a couple times, and always being a frustration, it was time for it to go away. In all fairness, the homebuilt pressure bleeder I put together went in the trash too. I'm sure it'd work with the right technique, but at the time it didn't meet my expectations and space is at a premium in my shop. As it is, I need to throw out a ton of parts that no one seems to need, and greatly thin the herd to give myself enough room to work.
Old Jul 11, 2019 | 05:52 AM
ResIpsa's Avatar
Personally I hate the mighty vac as well. But that’s just my opinion.
Old Jul 11, 2019 | 09:48 AM
OrangeBird's Avatar
Car: 1989 Firebird
....... I mean whichI cannot everget to seal while getting a wrench on the bleeder with one hand while pumping the mighty vac feverishly with the other hand to get a vacuum. All the while there is never any good place (unless you have three hands) to hold the little collection bottle which usually ends up popping open and spilling on the floor. And even if everything works perfectly you only have a brief period of suction and the collection bottle holds a tiny amount of old fluid.
You weren't using the same mighty vac as I have . The unit I have hooks up to a compressed air source and through venturi action creates a really strong vacuum into a 2 1/2 gallon catch container . Yes indeed I'll bet the little hand pump unit would be useless for bleeding anything , but it's big brother does get the job done .
Very well said and I agree 100%
Old Jul 11, 2019 | 01:20 PM
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
I picked up the motive bleeder a few years back, great product. I also grabbed 2 of the bleeder catch bottles for the bleeder end. I found that the pressure bleeder is usually unnecessary and that putting a little fluid in the catch bottle to seal the stem works just fine in most cases. I have used it to pressurize the system so I could do the abs bleed procedure on my trucks. I found that for $20 you can turn it into a ls oil prime tool, and THAT is what makes this tool great. When put in the proper port it will prime the pick up tube, pump, and send the rest through the filter into the engine.
Old Jul 11, 2019 | 01:51 PM
ResIpsa's Avatar
I never thought about using it in that way. Pretty cool!
Old Jul 11, 2019 | 02:06 PM
ResIpsa's Avatar
I know that came across as pretty snarky. I honestly was not aware it could be used as a suction bleeder.
However, it would be really cool to know how to use it in that fashion. Could you explain how you do that?
Old Jul 11, 2019 | 03:04 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
It's not a suction bleeder, you would use it exactly like you're using it, just from the remote end
Old Jul 11, 2019 | 04:29 PM
ResIpsa's Avatar
Do you mean pushing fluid through the bleeder up through the system?
Old Jul 12, 2019 | 10:10 AM
OrangeBird's Avatar
Car: 1989 Firebird
I would be interested to see how that works as well , my thought being that since the bleeder threads are loose enough to require my O ring trick to get a good vacuum when vacuum bleeding , wouldn't pressure bleeding attempted at the bleeder push a bunch of fluid past the threads (and onto the floor) instead of up through the system ?
Old Jul 12, 2019 | 10:13 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I remember reading a post where someone had to bleed from the caliper, I it may have been a completely dry system though
Old Jul 14, 2019 | 11:28 AM
GeneralDisorder's Avatar
As to the question of power bleeding the clutch hydraulics - yes that absolutely works. I don't have the Motive - I have a real brake flush system in my shop that has a pump with adjustable pressure. You dial in about 20 psi, break loose the slave at the bleeder (aftermarket slave), couple of pumps of the pedal and it's bled in about 5 seconds. I was astonished - I had perfect firm pedal in three pumps.
GD
Old Aug 22, 2019 | 06:36 PM
Schurkey's Avatar
I've bled hundreds of brakes. I've used every method EXCEPT reverse-injection using a special tool. I've done "reverse" bleeding using the piston of the caliper, but never with a special tool.
If they were giving away Motive "garden sprayer" bleeders for free, I wouldn't walk across the street to get one. There's no rubber diaphragm to separate the pressurized air from the brake fluid, so the brake fluid pulls the moisture out of the air you're pumping into the "garden sprayer". The longer you leave the fluid in the "garden sprayer", the more contaminated it gets--until the humidity is gone from the air and it's all in the fluid.
Pressure bleeding using a REAL pressure bleeder that has a rubber diaphragm--not a converted garden sprayer--is a truly wonderful experience especially if you're doing major brake work so the system is fairly empty; or the existing fluid in the brake system is heavily contaminated so you need to flush a large quantity of clean fluid through the cylinders and tubing to remove all the old fluid. When it was my money, I bought the Branick pressure bleeder; but I had a K-D (now called "Gearwrench") pressure bleeder before that. Both worked great, the KD eventually died of old age; I bought it used and had it for at least a decade and I bet it was ten or twenty years old when I got it. The Branick is now about fifteen years old, and looks like new as it's not used professionally. Yes, it costs more than a piece-of-crap garden sprayer.
https://www.branick.com/product/g300...brake-bleeder/
Be aware that Branick changes the adapters included with the pressure tank assembly from time to time, what's included now is not what was included when I bought mine all those years ago. I've bought extra adapters, and I had some from the K-D bleeder, so I'm pretty-well set to bleed any car or light truck that's at least ten years old or so.
Pressure bleeding takes a moderate amount of set-up time, and a moderate amount of put-away time. It takes longer to get the pressure bleeder out of it's storage area, select and install the correct adapter, and then take the adapter off the vehicle, clean the fluid off of it, and put the whole works away, than it takes to actually USE the equipment to bleed the four corners of a vehicle most of the time. Set-up and take-down time--and having to fill the bleeder once in awhile--is the worst thing about pressure bleeding once you've paid for the bleeder.
Just for the record, I don't use the Branick all that often, because for minor work at the wheels on a system that was already functional, I gravity-bleed.
Gravity bleeding has essentially no set-up or take-down time. The downside to gravity bleeding is that the actual bleeding takes way longer than pressure bleeding (but I can always put away tools or clean-up the shop while I'm waiting, so it's not "wasted" time.) It also doesn't work well if the system was empty, or became empty due to replacing lots of parts.
I have vacuum-bled; I don't like it. It does work better on disc brake calipers than on drum brake wheel cylinders. You'll pull air past the bleeder screw threads unless you seal it to the rest of the wheel cylinder, and you'll pull air past the seals of a drum-brake wheel cylinder. Wheel cylinder seals are designed to keep fluid IN, not to keep air OUT. So vacuum-bleeding generates heaps of bubbles and you never know when the system is "done".
I have been in both positions when one guy pumps the pedal, and the other guy opens the bleeder screw. It stinks unless your helper is a Victoria's Secret model.
I've reverse-bled by pushing the piston back into the caliper. If the pads were very worn, there's a surprising amount of fluid trapped behind the piston. It can work really well because you're pushing the air in the direction it wants to go anyway--up! Problems are, 1) the fluid in the caliper is probably the most-contaminated fluid in the system, and you don't want that going through the ABS valves. So you have to bleed the normal direction to flush the contaminated fluid out, then bleed "backwards" to push the air "up" and into the master cylinder. If you've bled the normal direction...the air should be gone and there's no need to reverse bleed. 2) Many master cylinders are mounted so that the front is tipped "up". Any air pushed backwards through the system is trapped in the front of the master cylinder because the reservoir connects farther to the rear, and the front is higher than the rear. You might have to unbolt the master to level it or even tip it "down" in front to get all the air out of the master cylinder and into the reservoir. Reverse bleeding works great on motorcycles, though, where you can change the angle of the front master cylinder by turning the handlebars. And NO MATTER WHAT, fancy tool or pushing the caliper piston, you MUST bleed in the normal direction after "reverse bleeding" because the bleeder screw is higher on the caliper or wheel cylinder than the fluid hose port, so there's air trapped above the hose port in the cylinder that's only going to be released by bleeding out the bleeder screw.
Old Aug 23, 2019 | 10:51 AM
ResIpsa's Avatar
The flat out hate for the Motive Power Bleeder on this forum is almost funny.
I suggest you go to your local road course on any given weekend and take a stroll through the paddock. What are the racers using?
Or at least take a cowbell to sound the alarm that everyone is putting their life and vehicle at grave risk.
Old Aug 23, 2019 | 11:49 AM
skinny z's Avatar
I actually tried to make my own version of the Motive bleeder by adapting a schreader valve to a spare MC lid. The difficulty was the MC cover seal not being able to stand up to the couple of PSI I was applying. Gave up on that experiment and then discovered this:
The general consensus about the Motive Power Bleeder notwithstanding, I've had great success with this pneumatic bleeder. (It may have been mentioned here already in some form or another).
Old Aug 29, 2019 | 11:57 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
was just looking at this tool, and then OF COURSE googled to see if anyone at TGO had used it. Thanks for the review! Looks like it would be really handy for cars which have screw on caps on the fluid reservoir
Old Aug 29, 2019 | 12:02 PM
LiquidBlue's Avatar
Transmission: MD8
P.S. on this,
Amazon Amazon
check out before buying, apparently the adapter that ships with the entire kit is too small for our cars. we need adapter 1115
https://www.motiveproducts.com/pages/application-guide
Ginko1
Brakes
Nov 13, 2013 03:01 AM
Jaime-TA-84
Brakes
Sep 8, 2006 02:19 PM
indirocz28
Brakes
Mar 29, 2006 05:54 PM
Luther6704
Nov 3, 2002 08:46 PM
Golden80
Jan 18, 2002 02:19 PM
