9 bolt brakes
Old Jun 6, 2025 | 11:27 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
9 bolt brakes
Yes I did a search. I have the 89 9 bolt brake brackets, what upgraded brakes can I run with my 9 bolt ?
Old Jun 7, 2025 | 01:13 AM
Drgnbld's Avatar
Car: 89 GTA
Transmission: auto
Axle/Gears: 3.23 BW 9 bolt
Re: 9 bolt brakes
I'm going with C5 brakes for my 89 with the 9 bolt. I got the kit from big brake upgrade. I have pics of them on my 89 GTA refresh post. https://www.thirdgen.org/forums/memb...a-refresh.html
Old Jun 7, 2025 | 02:09 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 9 bolt brakes
"Most" upgrade kits will have new brackets. However, there are a few that may work w stock bracket
Old Jun 7, 2025 | 02:14 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: 9 bolt brakes
3.70 axle ratio wasn't available in 89, so did you change/upgrade the gears, or was it a complete axle swap to an 85-86 9-bolt, which were the only two years that came with 3.70 and had the older style rear disc brakes?
If it's an 89 9-bolt, then its backing plates should be for the Performance Package ("1LE") PBR rear disc brakes, which was the upgrade for 3rdgens and considered desirable to most people. If that's what you have and want to keep, then 89-92 and the far more accessible 93-97 calipers bolt-on.
If it's the 85-86 9-bolt, then you should scrap those backing plates and upgrade to anything else, such as the 89 "1LE" backing plates (if you can find any), or C5/C6 backing plates (which BBU modifies, if he can still get them; they were discontinued a few years ago but may still be accessible).
LS1 rear backing plates require modifying the bolt pattern to fit a 9-bolt, which a couple of people have done. They used to be available only through junkyard salvage (used), but Hawk's had them reproduced. Again, the bolt pattern would have to be modified because there was no 9-bolt, only the 10-bolt.
1998-02 Camaro/Firebird Hawks Motorsports LS1 Backing Plates, PAIR - Hawks Third Generation
Scroll through these three pages of more up-to-date rear upgrades for 3rdgens from BBU, some for which Scott adapts to the 9-bolt.
Rear Brakes
Old Jun 7, 2025 | 05:48 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: 9 bolt brakes
I have the 89 PBR plates from an 89 car I parted out a long while back and the original 89 rear from my car that was stolen.
I’ll look on the BBU site and look at the rear stuff when I get the 4th gen stuff.
thanks much.
Rear Brakes
88tpi350
Jul 1, 2008 06:18 AM
jamon8
Dec 27, 2007 05:29 AM
Stephen
Brakes
Sep 10, 2007 08:42 AM
KustomIroc
May 29, 2002 08:20 AM
