I've got a 90 IROC hardtop for sale. The motor was pulled and rebuilt to a 383 with Scat Rotating assemble. Also has TPIS Miniram with DART aluminum heads, TPIS custom grind cam, full roller rockers. The engine has not been ran since the rebuild and balancing. The car has been swapped over to a T56 transmission as well. I have new shocks/struts to go along with it and EFI Connection 24x management system that hasn't been installed. Current the engine is in place but the transmission still needs to go in and the wiring harness has been partially pulled out to get the 24x system in but no wires have been clipped. The body is in great shape and only a small dent in the right rear quarter panel that can easily be hammered out. I have tons of money in this but I really have lost interest in the project.
For the interior I have a newer OEM dash pad to install, but I pulled the dash shell to try and route the 24x system so that needs to go back in. The car has everything it needs to run and drive, just needs time that I don't have or care to put in anymore.
$3500.
Reason: Sold
Yes I’m aware of that. It was previously repainted prior to my ownship. You can tell also by the headlight rests are red instead of black. It’s a 90, has the half moon gauges and Speed density system instead if MAF.
