Camaros Wanted Looking to buy a specific Camaro? Post your Want Ad here.
WTB Nice F-body for under $4000
Old May 15, 2006 | 05:16 PM
a mack6's Avatar
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
Ok finally got my insurance settlement on my 92 Camaro. Were getting alot of money back but my parents are only giving me back what i put into it in the first place so im gonna have around $3000 possibly up to $4000 to spend on a new F-body.
Im willing to look at alot of different stuff, but i'm more inclined to go with lower mileage/original cars than a car that has been hacked up and modified alot. Its also important that the car be within a few hours drive of me (Allentown,PA).
Things the car must have:
-V8- Lo3, Lb9, and L98 are all fine.
-Nice interior
-Needs to be able to last me through college (i'm going to college in pittsburgh so i will only be driving the car during the spring/summer. I expect to put about 4-6k miles on each year).
-Can't look whitetrash!!!
Old May 16, 2006 | 01:41 AM
Spqrz28's Avatar
Car: 1984 Z28
Engine: 350 ci 300hp crate motor
Transmission: t-5
I have a nice one. I am in NC check it out in for sale forum
Old May 19, 2006 | 07:42 AM
loudchevyz28's Avatar
I have an 86 Z28 located in IL for $4,000.
Old May 19, 2006 | 01:49 PM
8579's Avatar
'92 near Nazareth
I have a '92 RS, t-tops, purple, 305 (v8) automatic about 30 miles away. It could use a paint job, but isn't bad (just pealing in a few spots). Nice gray interior with one small cigarette burn hole in the pass. seat. It has 160000 miles, but is in nice shape with a jasper trans. replaced around 130000. The guy who had it before me put on a neon ground effects (underglow), and did a pretty good job. Needs the heater core replaced (currently bipassed) if you want heat (I didn't take it out much in the winter). Cost about $300 to have it done. $3000. Let me know (610-599-0215).
Old May 20, 2006 | 06:50 PM
yjischoking's Avatar
Car: 95 Acura Integra GS-R
Engine: B18C1
Transmission: 5 spd.
i see you had a heritage. ive got a red w/ black striped t-top heritage RS for 4k. rebuilt motor w/ 32k on it right now. 122k on the body/4l60e.
car has koni yellows, eibach pro-kit, earls stainless lines and hawk pads, 36/24 swaybars, 245 in front 255 in rear g-force sports, flowmasters, k&n, tbichips.com chip and a clean interior.
lemme know if you're interested.
Old Jun 6, 2006 | 06:07 AM
eviltaoo's Avatar
have 95 z28 for 3600$,email me me if interested,eviltaoo@aol.com
Old Jul 22, 2006 | 11:04 PM
DGraboyes's Avatar
Car: 1991 Camaro RS T-Tops
Engine: 350 TBI now carbed
Transmission: replaced T5 w/new clutch
Axle/Gears: New 3.73 posi
its a 91 camaro rs used to be 305 TBI now 350 carbbed..but i am putting back on a newer TBI because i dont like how it worked...i took out the AC compressort and re rerouted the serpintine belt to just run the water pump, crank, alternator, and power steering, the smog pump is still attached, but not hooked up. none of the emissions are hooked up but i have everything to put back on it if you want it. i have new chrome valve covers, new spark plug wires (many sets) if you want them, bosch +4 spark plugs installed, new edelbrock shorty headers with replaced collectors and a cutoff flange installed with a remote switch. The exhaust is Flowmaster and there is no rust whatsoever on the car. I have installed a multi-color LED underbody kit and an oogah horn in addition to the regular horn. New struts (lift supports) on the hood and hatch, T-tops are in great condition with no scratches and barely leaks unless direct pressure is put on a certain area. i just put in a remanufactured T-5 transmission because i didnt like mine and a new Luk clutch. I replaced the rear gears from 3.23 to 3.73 because of wear. Has IROC rims with newer Nankang tires with excellent tread. Never been in an accident, has a few paint scratches that i have touch up paint for but never got around to it, no dents, minor ding on the hood (not noticible from far away), original white paint, original red interior with minor tears in dirver seat from normal wear. New Sony X-plod head unit with new Bazooka 4 Channel amp that powers the front Boston Acouctik and the rear JBL 6x9. Also new Boss amp that powers the 2 PPI 10" subs with remote amp control. I just installed a air/fuel ratio gauge for the carb but i will leave it in for the TBI. New Sylvania Halogen Lo-beam headlights (the high intensity ones) and a replaced ignition switch in the steering column. I still have a few more mods i want to do but let me know what you think and im not gonna stop working on this until i sell it because i am going to college in Texas and i dont want a car there..lookin for about 4000
for pics email deangraboyes@gmail.com
Old Aug 4, 2006 | 11:04 AM
Bad Blue IROC's Avatar
Car: 1989 IROC-Z
Transmission: t56
Axle/Gears: 410
1989 RS
i have an 89 rs located in felton DE. it is stock for the most part it has a new rear and som body modifications but thats about it. the car is in primer so u will have to paint it. i am asking $2,000.
Old Aug 4, 2006 | 04:06 PM
scott5's Avatar
pm'd you
Old Aug 4, 2006 | 04:16 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
EDIT: just noticed this is in Camaros wanted section.
I'll let you have my 88 Formula with no wheels for $4000.
Old Aug 11, 2006 | 11:57 AM
knoxie90's Avatar
Car: 92 RS Camaro
Engine: 305 tbi
Transmission: 5-speed
92 rs
i got a 92 rs for sale and all the info is on the link.
BEAUTIFUL CAR!!!! >>> https://www.thirdgen.org/forums/cama...rs-camaro.html
Old Aug 15, 2006 | 03:12 PM
MiZZiE's Avatar
Car: '88 camaro/ '89 gmc s15 lower'd.
Engine: 305tbi 5.0 & 4.3v6 soon to be 350.
Transmission: 5spd manual/camaro.. auto/s15
i'm in RI which isn't too far from PA. i have this for sale.. in VERY good condition...
1988 camaro 305v8 tbi 5spd. t-tops, 74k miles all original, body/paint is PERFECT not a speck of rust on the car., interior very clean, engine/engine bay you can eat off of.. car is clean all around. was stored in a climate controlled garage for about 8 years ran periodically, never seen snow or the elements, never beat on, engine is all orignal un-fooled around with...no aftermarket parts (besides obvious plugs,filters etc just regular maintance parts)i have all orginal paper work & manuals for the car... needs nothing (i'm in the process of intalling new filter and section of new fuel line). car is very clean all around.
heres a link to the Mautofied.com classified add... price is definetly negotiable so make an offer...i'm also interested in possible trades..
http://www.mautofied.com/listing-100029866.html
let me know if your are interested, i have a million pictures of the car if interested in seeing more. PM or email me stripersearch@netzero.net.
later,
-Mike
Old Aug 17, 2006 | 06:00 AM
85C4's Avatar
Car: whatever has the most gas in it
Engine: GM v8
Transmission: Uumm that's contingent
Axle/Gears: See prior line
86 Iroc, 5spd, 383 etc
check this out:
https://www.thirdgen.org/forums/cama...ml#post3025498
Old Sep 3, 2006 | 09:20 PM
DGraboyes's Avatar
its a 91 camaro rs used to be 305 TBI now 350 TBI..i took out the AC compressor and re rerouted the serpintine belt to just run the water pump, crank, alternator, and power steering, the smog pump is still attached, but not hooked up. none of the emissions are hooked up but i have everything to put back on it if you want it. i have new chrome valve covers, new spark plug wires (many sets) if you want them, bosch +4 spark plugs installed, new edelbrock shorty headers with replaced collectors and a cutoff flange installed with a remote switch. The exhaust is Flowmaster and there is no rust whatsoever on the car. I have installed a multi-color LED underbody kit and an oogah horn in addition to the regular horn. New struts (lift supports) on the hood and hatch, T-tops are in great condition with no scratches and has leaked once on me through a car wash...needless to say i hand wash it now. i just put in a remanufactured T-5 transmission because i didnt like mine and a new Luk clutch. I replaced the rear gears from 3.23 to 3.73 because of wear. Has IROC rims with newer Nankang tires with excellent tread. Never been in an accident, has a few paint scratches that i have touch up paint for but never got around to it, no dents, minor ding on the hood (not noticible from far away), original white paint, original red interior with minor tears in dirver seat from normal wear. New Sony X-plod head unit with new Bazooka 4 Channel amp that powers the front Boston Acoustik and the rear JBL 6x9. Also new Boss amp that powers the 2 PPI 10" subs with remote amp control. I just installed a air/fuel ratio gauge for when the car was carbbed. New Sylvania Halogen Lo-beam headlights (the high intensity ones) and a replaced ignition switch in the steering column. I still have a few more mods i want to do but let me know what you think, i am going to college in Texas but the car is still in jersey with the title and i need to get rid of it so i can get something down here. Thanks for looking and let me know what is going on. Im asking 4000 but make me an offer i need this car to go..thanks
email at deangraboyes@gmail.com
Old Dec 5, 2006 | 12:48 AM
butch z's Avatar
Car: iroc z28
Engine: 305tpi
Axle/Gears: stock /aluminum rear drums
86irocz28305tpi metallic blue at ttops new fuel pump front rotors aluminum rear drums (rare)posi couple dents 89000 $2000 medina,ohio
Old Jan 25, 2007 | 06:29 AM
Gen 3 Fbody Fan's Avatar
Car: 91 Trans Am, 88 GTA, 90 Formula 350
Engine: 305TPI, 350TPI, 350TPI
Transmission: 700R-4
Axle/Gears: 3.27, 3.27, 3.23
1985 z28
I got a 1985 z28 with 305 TPI and t-tops, for sale under camaros for sale under the heading "1985 Z28 in Silver Spring, MD"
That may be too far, but figured I would let ya know
Hope you find what you are looking for
Old Jan 30, 2007 | 05:47 PM
dennism's Avatar
hey
i have a 1992 camaro rs 25th anniversary 305 tbi,,excellant condition,no rust,i have pics,3000.interior look great. pm me
Old Jan 31, 2007 | 01:22 AM
Kandied91z's Avatar
too bad your in pa, i have too nice rs v8's for only 2k each.
good luck finding one. i flew out to pa a few years back to buy a z28, it was so cut up i ended up leaving the guy at the airport. buying a thirdgen isn't fun.
pjsparts
Oct 29, 2025 06:39 PM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
