Camaros Wanted Looking to buy a specific Camaro? Post your Want Ad here.
Want to trade? come in side...
Old Jun 19, 2007 | 02:46 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
I have a 98 4thgen Z28 6 speed that makes 372rwhp (on a dynapack system which reads lower than the dynojets by 15rwhp) Tons of mods and over $7500 in new performance parts that were done in the last few months..
what i want is a 86-89 Iroc (possibly a 90-92 maybe) Camaro, must be a manual tranny, and V8 engine (TPI preferred )
if anyone is interested.. I please speak up.. I have title in hand.. car is clean, clear title.. I have about 40 pics on my cardomain site.. as well as a list of everything that was upgraded and bought for it.
looking for trade + cash..
here is the link to the cardomain website http://www.cardomain.com/ride/2270574
here is a list of mods that were done ... all engine mods were done in May of this year by me.. the brakes and suspension was done in Feb of this year.. the trans and clutch was done in April 06..
1998 Camaro Z28 6 speed
114,250 miles
Mystic Teal Metalic 1 of 472 made
T-top
Grey leather interior
NON smoker
here is the mod list and recent refreshing of this car.
Basically.. everything is new but the short block.. everything i list as "NEW" was done in the last 30 days or last week
Driveline
-T56 was rebuilt last year (i have only put 6k miles on it since) BY T56 rebuilds, 1B package + new 1st and 4th gear. will handle 750hp
-New SPEC 3+ clutch (installed same time as rebuilt trans) rated for 850tq
-New updated master cylinder
-New update slave cylinder
-Drill mod performed
-New Pro 5.0 shifter
-New Hurst white ball shift **** with 6 speed pattern etched in black
-new GM replacement flywheel
-new 3.73 gears
Now the following things were completed in the last 30 days.. some in the last week:
ENGINE:
-New 241 heads, milled .028
-New GM ASA Camshaft 226/236 .525/.525 110 LSA
-New GM head bolt kit
-New 03+ LS6 springs
-New GM MLS Head Gaskets
-New GM water pump
-New LS6 intake from GM
-New Pacesetter Long Tube ceramic coated headers
-New stainless steel band clamps for exhaust
-New Pacesetter ORY pipe
Texas-speed Rumbler catback
-New Bosch 13111 O2 sensors
-New LS6 oil pump
-New oil pressure sending unit
-New LS2 timing chain
-New center bolt valve covers
-New center bolt coil brackets
-New NGK TR55 spark plugs, gapped .55
-New MSD spark plug wires
180* thermostat
Granitelli air lid
Granitelli ported MAF
BBK 80mm throttle body
Suspension and brakes
Eibach prokit springs
Hotchkis Adjustable panhard bar
Hotchkis trailing arms
-New BMR bolt in relocation brackets
-New poly rear endlinks for sway bar
-New Prothane motor mounts
-New rear KYB AGX rear shocks
-New C5 Corvette 13" front rotor upgrade
-New Kore3 front C5 brackets
-New Severnmotorsports brake duct kit
-New JEGS 3" brake duct hose
99 silver ZR1 17x9.5 wheels (have some curb rash)
2 Sumitomo HTZRII tires 275/40/17 (2 years old, lots of tread left)
2 Sumitomo HTZR tires 275/40/17 ( 1 year old, tons of tread)
Duralast brake pads on all 4 corners (new since last year, lots of life left)
Grey leather, driver seat is power, driver seat is a little worn but no rips or tears in the leather anywhere. Back seats look brand new. Carpet is clean, rear is clean, T-top shades are good condition. Driver side T-top does not lock, but passenger side is fine. Power seat works awesome, tilt and cruise control work awesome, power windows and door locks are great. Center console lid is awesome too. Everything works, and is in great shape.
Only interior mods are:
-Autometer oil temp gauge mounted infront of shifter in custom holder
-Autometer Trans temp gague mounted infront of shifter in custom holder
-Autometer water temp gauge mounted in driver pillar (not connected)
-Autometer dual pod gauge holder
-Pro 5.0 shifter
-Hurst White shift **** with 6 speed ingraved in black
Exterior
Paint has a few chips in the hood and in the front bumper. There is also a small ding in the rear near the tail panel, otherwise looks great.
exterior mods are:
-Berger tail panel mod, shaved "CAMARO" and 1969 "Z28" symbol added to center rear.
-Whistler headlight mod
-Front stock grill removed
-Black painted billet grill with 1969 Camaro blue bowtie
Maintence done
-Newflushed coolant system, added new Dexcool coolant
-Newoil changed (100 miles ago) German Castrol 0w-30 (6 quarts)
-New Delco oil filter(PF46)
-New PCV vavle and gromet for driver side
-New PCV hoses
-New Dexron III fluid for transmission
-New differential fluid with GM posi lube
-New differential gasket
-New fuel filter
-New ATE Super Blue brake fluid, fully flushed
-New ATE Super Blue fluid for the clutch
-New Duralast battery ( 6 months old)
-New whiper blades (4 months old)
Tuning & Power
Tuning was performed by a local tuner, using HP Tuners. He has over 3 years experience tuning GM cars. AIR/EGR have been deleted, and have been turned off in the tune as well. This car was recently dyno'd (May 28 2007) on a DynaPack 4000. The car made 372.6rwhp SAE corrected and 378rwtq SAE corrected and yes i have the dynograph
Needs
very little.. the rear window tint needs to be replaced.. Also the power steering rack needs to be replaced. It has a small leak, coming from the driver side, or you can just replace the seals inside the rack.
.. this car is AWESOME to drive and sounds down right MEAN. I have only had it back together since May 26 2007.. so everything is new.. when i had it stripped down to its short block.. you could still see the honing marks in the cylinder walls.. and the block checked out great on the compression test.
the pictures of the car on cardomain were taken 6/4/07 I have since only put 200 miles on the car since i have completed the engine mods. I can get a soud clip up later on today if someone was to hear it.
Old Jun 23, 2007 | 11:06 PM
red89Irocz's Avatar
Car: (2) 89 Irocs, 97 Eclipse GS-T
Engine: (2) 350s, 2.0 turbo(4g63)
Transmission: 5-speed
Axle/Gears: 2.77 and 3.08, for now
Re: Want to trade? come in side...
I have an 89 Iroc with a rebuilt 350(carb) 11:1 compression with dome pistons, mild cam( don't know the specs), holley carb, holley fuel pump, rebuilt rear end (10 bolt) with disc brakes, lowered 1", stock t-5 and a roll-cage
I also have a 92 RS also with a t-5, this one is almost bone stock besides exhaust and carburated instead of fuel injected.
I'm generally not a fan of the 4th gens but yours is a real nice/clean car, anyway i would make you an offer and your pic of my 89 iroc and/or 92 rs....only problem is that I have no money(which is why i'm selling my cars in the first place)
Still pretty new here so i couldn't figure out how to insert pictures, but if you're interested let me know and i'll e-mail them to you.
Once again, they're for sale, not really for trade
Old Jun 26, 2007 | 07:47 AM
Z.ROC28's Avatar
Car: 1991 Camaro RS
Engine: 305 L03 TBI
Axle/Gears: 4th Gen 10 bolt posi / 3.43
I havn't been trying to sell or trade my car but your car caught my eye... Here's my five speed 91' RS.
Basically it has all the Z28 options added to it that came in 91-92. I have left the origionality to the interior, it's black/grey. Only flaws i know of in the interior is that rip that every camaro gets on the driver seat and the seat buckle skin is cracked. Everything else in the interior is flawless. Power windows were added by me, hatch release button has not been installed. Fog light switch was installed and soon to be wired up.
The engine is sound as can be for its mileage... 158k miles and still havnt had one problem since i bought it January of 2006. Tranny just got a fresh stage 2 (forgot the name) clutch (including new slave cylinder), throwout bearing, and pilot bearing. Along with that I installed a fourth gen. posi rear end with 3.42 gears and rear disk brakes. There's absolutley no whine at all from it. Also installed a new e-brake cable setup. A new brake master cylinder came with the rest of that.
Everything on this car is spotless. It was repainted in around 96' (?) I believe due to the 91-92 paint defects the GM vehicles had. The paint on this car provides a very sharp reflection. I'vve always kept this car waxed/detailed (I work as a detailer at a local boat dealership). Engine compartment is as clean as the rest of the car.
My final thoughts on this car: It's a great car, it was my first car, I was the second owner. It's been babied it's whole life. Only thing this car is missing is some power (305 if I didnt mention above). I've been trying to build a motor but I'm new to engine crafting and I'm having a hard time trying to figure out what I want to do with it. My father keeps telling me to keep this thing stock and dont get rid of it. A few months ago I gave up and tried to find a decent trade but no one really wants to meet my stated value for the car. If your interested just throw me a PM.
Holy crap I didn't realize you were way over in CA/Utah. Sorry lol.
Old Jun 26, 2007 | 01:49 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
very clean.. nice color.. nice upgrades.. dont worry about me being in UT and you in NC.. that part can always be arrainged...
what are you looking to get out of your car.. price wise.. ?
I take it, its a 305 TBI right? No worries.. i can convert that to 355 TPI like my last car..
do you have any pics of the engine and interior? you can post them or email them to me..
I am interested in it.. the part that remains is, what are you wanting for you car, + how much cash to get mine.. send me a PM if you dont want to post the particulars for everyone to see.
forgot to ask.. how far are you away from Raleigh? I have a sister that lives there..
Old Jun 26, 2007 | 02:27 PM
yjischoking's Avatar
Car: 95 Acura Integra GS-R
Engine: B18C1
Transmission: 5 spd.
what kind of mileage do you get w/ the heads/cam/gears? how much straight up sale? dont suppose you would consider a trade for a gsr integra?
Old Jun 26, 2007 | 02:38 PM
Z.ROC28's Avatar
Car: 1991 Camaro RS
Engine: 305 L03 TBI
Well since I'm not in "need" of another car and I have nothing wrong with this one I'm pretty much trying to get around $7,500. I've invested about 9,500 not including the price I paid for it. And yes I did forget to mention it is a TBI. There's no rust on the car, most of the mileage is highway from the previous/first owner using it for traveling during his times in the Navy. I believe he said this car was stationed in Guam for a while too I believe. Other then traveling, the car has always been here in NC, it was also bought brand new from here. I'll have some pictures for you within the next hour or so. I'll give you some pictures of those two flaws I mentioned above. I also forgot to mention, it has a $1100 audio system (Kenwood Exceleron all the way around, 2 JL 12" W1V2 subwoofers in a custom enclosure. Which of course can come with or without. The only flaw you can see on the car on the exterior is one of the exhaust pipe's is bent over about an inch or so (its not parallel) but it's not very bad. I'll take a picture of that too. But I'm not sure how much I'd give you if I were to trade, what value are you looking at for your car?
Old Jun 26, 2007 | 03:46 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
i could see spending 6000 on a 350 TPI car.. but not 7500 on a 305 TBI.. i mean your car is clean.. dont get me wrong.. but i just dont see spending that much on it.. and you say you invested 9500 on it.. in 6 months... ok.. where? what did you get for 9500?? was the car in horrible condition before?
I bought my last thirdgen (92 RS TBI 5 speed) New paint, good interior, 97k on the clock.. everything worked great, for $3500.. granted everything was stock..
I converted it to a 355 TPI, then added an aftermarket 6 speed, 4thgen rear end, suspension parts, 4thgen leather seats, 17x9.5 ZR1 wheels, ect ect.. and only got 6,000 for it.. so.. if thats your price.. then i must pass...
Old Jun 26, 2007 | 06:51 PM
UgotSmoked's Avatar
Car: 88 IROC-Z
Engine: fully built 383 stroker
Transmission: Tremec TKO-600
Man i would love to trade! but im really trying to sell my 88 iroc! 383 stroker tremec tko-600 5-speed! if i could i would love to trade it!
Old Jun 26, 2007 | 06:58 PM
Z.ROC28's Avatar
Car: 1991 Camaro RS
Engine: 305 L03 TBI
Well like I said, I don't have a need to get rid of this car, and that is just what I was trying to get, I didn't mean that in terms with you. That's why I asked how much your wanting for you car? Plus it wasnt spent over six months, I bought this car in January 2006, which is a year and six months. All that money is basically everything you see on the car, the rear end, the tranny work, the wonderbar, the money spent restoring the paint, the wheels, the audio system, the fog lights, the switchs, the wiring, the tint, the paint job on that brand new hood sitting on there with the power blister, the power blisters them self, exhaust work, the viper alarm system, need I go on? If you'd like me to go into the backroom and dig out my paper with all the costs on it I will do so and list everything... Anyways... Here's some pics I just took for you. And as I said before I'm not looking to get 7.5k, thats what i was trying to get, I wanna hear what you have to offer for a trade + cash (me paying cash with trade).
Old Aug 7, 2007 | 06:16 PM
UgotSmoked's Avatar
Car: 88 IROC-Z
how about you just buy mine and keep them all! lol! cant have too many toys.
Old Aug 12, 2007 | 11:18 AM
CC's Avatar
CC
Car: 1989 Trans AM GTA
Engine: 5.7 TPI - Stock
Hi I have a 1988 Iroc-Z28, 5 speed TPI, 112K miles for trade. Idles, runs and drives excellent. Car was purchased in the west coast Oregon and trailered to Chicago/Ohare. Factory installed options:
• 305 LB9 220 hp
• 5 spd manual WORLD CLASS trans
• T-tops
• manual windows/door locks
• Rear defrost
• 2 stage windshield wipers {no intermittent}
• Factory Alum driveshaft
• Alum drums 3.08 posi rear end
MODS DONE:
• Professional Basic Rebuild .030 over 305 stock CR
• Mild camshaft
• Throttle body coolant bypass
• TPS adjustments
• Ram air mods
• Full ceramic coated headers w/y-pipe
• Cutout, and flowtech catback system
• Alum water pump
• Smog pump delete and cat delete
• Accel wires
• 180 t-stat
• 13.70 sec 1/4 mile, 13.40 on radials
• 19 mpg city 28 mpg highway (best)
if interested please let me know: powerbookem@yahoo.com
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
anesthes
Sep 30, 2015 07:48 AM
