WTB: 91/92 Z28 G92 RED
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
I want to build a road racer. I don't really care about miles, but I want the body and interior to be straight and clean. I am very picky and will not consider anything other than a 91 or 92 red with black or gray interior. Must be G92 LB9 or L98 with a quality T5/T56 conversion. I will also consider a 1LE. I am in Northern Virginia.
Car: 91 CAMARO Z-28 G92
Re: WTB: 91/92 Z28 G92 RED
i have a red w/ tan interior 91 g92 t-5 w/ lb9. trans, clutch assy, and bellhousing needs replaced
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
Couple questions...
Do you have any pictures?
How many miles?
Is it stock?
Does it have J65? (I had a 91 G92 w/o this option for some reason).
How many miles?
Is it stock?
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
Everything you'd want, plus more. '91 Z28 L98/T56 Red.
https://www.thirdgen.org/forums/cama...8-l98-t56.html
it has 104,281 miles on it. when i bought it it had a fresh rebuilt motor from a great local rebuilter (have paper work) it was put in at 69,177 miles. (have paper work from GM in Canada)
. many many bolt ons just about everything you can do. nos, msd digital 6, headers, exhaust, drag radiles, new bushings etc....
also have all paper work since i bought the car down to the oil changes. i can get pictures if you are serious, and i will look tonight for that J65 code. (what is that code for?)
. many many bolt ons just about everything you can do. nos, msd digital 6, headers, exhaust, drag radiles, new bushings etc....also have all paper work since i bought the car down to the oil changes. i can get pictures if you are serious, and i will look tonight for that J65 code. (what is that code for?)
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
J65 is for rear disc brakes. Most G92 cars should have them, but some managed to slipped out without them (like my previous one).
Honestly guys, I am not looking for anything that's been modded (definitly don't want t-tops). Mostly, it will put me in a tougher class, and since I'm a novice, I want to start out with the newbies. Besides that, I want something simple to repair when things go wrong and not have to wonder what has been done or hacked previously. This is why I say "quality" T56 conversion.
I'm willing to take my time to find the right one. I appreciate the replies!
EDIT: That sure is an amazing car Cam-aro. You RARELY see 3rd gens like that. Unfortunately, most people who are in the market can't afford one in that shape. If it had a LSx engine, it would sell quickly. Good luck with the sale.
Car: 1991 Z28
Transmission: 5 Sp
It's a '91 Z grey interior, nice body, rear drum, Accel Ign., Dynomax exhaust, 114K +/- Miles, pretty much a stock car. Sits in my garage and doesn't get driven alot.
Car: 92 Z28 / 66 Biscayne
Engine: 355 / 427
Transmission: T5 / M22
Axle/Gears: 3.42 Posi / 3.73 Posi
Just curious, How far are you willing to travel?? We may need to talk...
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
Wow, that's perfect. You are ALLLL the way on the other end of the country, though. Ugh...
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
