Camaros Wanted Looking to buy a specific Camaro? Post your Want Ad here.
1988 IROC 5 spd hardtop
Old Nov 25, 2013 | 08:02 PM
Dbl_D718's Avatar
Car: 2007 Legacy GT spec.B
Engine: 2.5T
Transmission: 6MT
I've wanted an IROC since I was like 4 years old, and I can afford a second car now, so I want to make it happen.
The IROC I want must be an '88, hardtop, and factory 5 spd. These are just some things I'm set on. I will wait however long it takes to find one. I also want one with zero rust. I live in IL in the salt belt, but I'm willing to fly anywhere in the country to bring the right car home.
So those are the main points. Other criteria aren't nearly as important, but the perfect car would have:
- 4-wheel disc brakes (RPO code: J65)
- Performance rear axle (RPO code: G80)
- Limited slip differential (RPO code: G92)
- External oil cooler (RPO code: KC4)
I don't want a pile of junk, but I do intend the car to be a project, so it doesn't need to be in perfect shape at all.
EDIT: I've decided to go a different direction and am no longer looking (unless you offer me a deal too good to pass up).
Old Nov 28, 2013 | 08:03 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: 1988 IROC 5 spd hardtop
Not to pry or be a dick but why JUST an 88? 89 was basically the same car. Same dash and options and had a bit more power stock as well. You could find the same stuff you want in an 89 as well. Im just trying to expand your search criteria so you can still find what you want.
Old Nov 28, 2013 | 12:21 PM
Dbl_D718's Avatar
Engine: 2.5T
Transmission: 6MT
No worries, it's a valid question. I'm set on an 88 just because it's something my dad and I always talked about doing, working on a project car from the year I was born. So yes, an 89 would be basically the same thing, but I'd just prefer an 88.
Old Nov 28, 2013 | 12:36 PM
trafficlightguy's Avatar
Car: 1988 iroc
Engine: 350 30 over
Axle/Gears: Series 2 373
I have one but it has a auto with the t5 conversion kit already to go in trans is rebuilt by bullet proof trans with receipts has a 373 disk rear and is a 88 carb 350 30 over done last summer needs nothing
Old Dec 2, 2013 | 04:51 AM
((Mike))'s Avatar
Car: 1969 RS Z28 X33 Norwood built
Engine: 383 Stroker
Transmission: T10 4 speed
Wait for exactly what you want. Right down to the color and options. Its out there. Believe me! I have compromised in the past and always regretted it. I hope you find exactly what your looking for. When I decided to buy one of these I found exactly what I was looking for in just a couple months. Wow you were born in 88 when I graduated from high school. Man I feel old.
Old Dec 6, 2013 | 12:31 PM
tglennon11's Avatar
Car: 87 IROC
Axle/Gears: LS1 10bolt w/ 3.73
Not sure what other options this one has, but so far it fits the bill, and its IL.
http://chicago.craigslist.org/nwc/cto/4181307052.html
I like seeing these cars get restored/restomodded, tastefully, so i hope it works out.
I have seen this particular one up on CList for a while, so not sure how flexible that price is.....
Being an IROC it should have the limited slip, (my 87 T5 came with 3.08 posi and drums) rear disks would be a toss up, and worst case you can add the oil cooler, i have seen the setups on craigs and here-
Old Dec 6, 2013 | 04:27 PM
Dbl_D718's Avatar
Engine: 2.5T
Transmission: 6MT
Thanks for the post. I've looked at that one a couple times, but the it looks kinda rusty on the wheel arches, and that scares me away. Rust is the one thing I don't think I'm capable of repairing.
Old Dec 6, 2013 | 04:42 PM
tglennon11's Avatar
Car: 87 IROC
yeah, i saw that too, might just be body damage, not necessarily rust. I figured it was worth passing along.
just FYI- I bought my 87 in milwaukee, originally 305tpi t5 ttop car, and its only rust was the battery tray. and I mean ONLY rust. it was originally a west coast Oregon car. So its out there. Just be dilligent.
I have dealt with rust before too, its not fun at all.
Old Feb 12, 2014 | 12:18 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Have you seen mine? It's for sale.
Old Mar 14, 2014 | 09:04 PM
ev305tpi's Avatar
Car: 92 & 91 Z28 1LEs, 87 IROC-Z, 90 ZR1
Engine: L98, LT5
Transmission: 700R4, 6-speed
Axle/Gears: 3.45, 3.42, 3.73, 3.27
Looks like exactly what you are looking for http://worcester.craigslist.org/cto/4310786766.html
Old Mar 14, 2014 | 09:17 PM
Dbl_D718's Avatar
Engine: 2.5T
Transmission: 6MT
Yes, it definitely is. It's been listed on Autotrader for several weeks and I've exchanged emails with the owner. It's just out of my price range, unfortunately.
There's two others on Craigslist that I'm trying to work out deals for right now.
stalkier
Aug 21, 2015 01:54 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
kyleb24
Aug 15, 2015 08:24 AM
Randomtask2
Aug 13, 2015 01:57 AM
mustangman65_79
Aug 11, 2015 03:17 PM
