Canadian Region Take off to the Great White North.
Pour les Québécois
Old Aug 16, 2010 | 02:42 PM
  #251
iroczRyder's Avatar
Car: trans am 88
Engine: 305 a carbu, un 400 de coté
Transmission: th-400
Axle/Gears: 2:73 (pas sur)
Re: Pour les Québécois
maintenent que g eu un f-body je suis redevenus un gentil homme
Old Aug 16, 2010 | 02:57 PM
  #252
iroczRyder's Avatar
Car: trans am 88
maintenant que g eu un f-body je suis redevenus un gentil homme
Old Aug 16, 2010 | 03:02 PM
  #253
iroczRyder's Avatar
Car: trans am 88
desoler pour le double post, doit etre un peut trop sous...
Old Aug 27, 2010 | 10:34 PM
  #254
pat_z28's Avatar
Bonjour a tous , je suis de gatineau je vien de m acheter une z28 1991 avec un 305 tpi mais j ai de la reparation a faire dessu .
hi you all , i am from gatineau and i just bought a z28 1991 with a 305 tpi but i have some work to do on it .
Old Aug 29, 2010 | 11:42 PM
  #255
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Hey Pat_Z28! Welcome to TGO.. So, what kinda work are you lookin' at for your 91 Z?
Old Aug 30, 2010 | 10:13 AM
  #256
pat_z28's Avatar
hi , first i think the tps sensor is gone because the engine keep floding and wen i take off the injectors it start and run good for 10 sec but wen i put back the injectors the car starts but after 4sec it's floding again and it stalls .
after that she needs a new exhaust , new hand brake cable and floor work on the driver side .
i only paid 1500$ so it's not bad the body is in good condition and the engine as 114 000 klm on it .
Old Aug 30, 2010 | 11:10 AM
  #257
These cars are notorious for rusting under the driver's side floor panel. Ur lucky if that's your only rust issue. I don't drive mine in the winter or even when it rains for that matter. I'm in the process of POR15'ing the whole underbody so it will forever be rust free.
Was there any work done to the engine like a cam change or anything? That would potentially cause the ecm to compensate for what it thinks is 'not enough fuel' and then dump more in there by mistake. Oxygen sensor could be bad as well... TPS sensor is around 40$ i think, I bought one last year.
Old Aug 30, 2010 | 11:17 AM
  #258
pat_z28's Avatar
i think the engine only had maintenance .
as for the floor yes the subframe is rusted a litle bit to on that side ..
Old Sep 21, 2010 | 04:42 PM
  #259
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
Salut je me demandait si a part poncho(jai déja demander mais il ne semblait pas interessé de m'aider) il y avait du monde au québec qui font du fine tunning avec un tpi modifié.ECM programming etc... ( jai un setup lt-1 avec sensors de tpi) y roule mais pas au poil je cherche des passionné de tpi pcq personne arrive a maider svp!!!
mon pcm es chippé avec un pcm de pcmforless.com mon moteur tourne carré et le idle es super instable je crois que le melange es super riche au idle...pi pauvre WOT pi gros back fire...sauf ca la bien du coeur pu du potentiel juste mon projet va mal depuis plusieurs anné pi je veut pas vendre le char svp aidez moi!!!
Old Sep 22, 2010 | 09:43 AM
  #260
FOXGTA89: Salut. D'apres moi, avant de mettre plus de $$ dans un autre chip, check si ton chip a tout les bon settings. Example: J'ai delete le AC, EGR, SMOG PUMP, COLD START INJECTOR... Quand j'ai faite ca mon moteur rouler comme la marde... La, jai changer les parametres dans le ECM pour supprimer le AC, egr, smog, etc. dans le chip, et voila, ca rouler comme normale! Mais l'affaire c'est que toute ces choses vont affecter le idle, etc. si le tune est pas bon. Verifie si le chip que t'a commander de PCMFORLESS.com match avec tous ton setup lt1.
Tu l'avait dit que ta un LT1 avec des sensors TPI... Je savais pas que c'etait possible lol... Honetement le meilleure chose a faire c'est de tuner ton ECM toi meme, petit a petit, et pi tu va l'avoir le meilleure tune de meme.. C'est ca que je suis en traine de faire et c'est pas facile mais il y'a beaucoup d'information sur cette forum, faut juste lire toute ca.
Old Sep 22, 2010 | 03:33 PM
  #261
FOX-GTA_89's Avatar
FOXGTA89: Salut. D'apres moi, avant de mettre plus de $$ dans un autre chip, check si ton chip a tout les bon settings. Example: J'ai delete le AC, EGR, SMOG PUMP, COLD START INJECTOR... Quand j'ai faite ca mon moteur rouler comme la marde... La, jai changer les parametres dans le ECM pour supprimer le AC, egr, smog, etc. dans le chip, et voila, ca rouler comme normale!(JAI DEMANDER TOUT CA DANS MON CHIP) Mais l'affaire c'est que toute ces choses vont affecter le idle, etc. si le tune est pas bon. Verifie si le chip que t'a commander de PCMFORLESS.com match avec tous ton setup lt1.
Tu l'avait dit que ta un LT1 avec des sensors TPI... Je savais pas que c'etait possible lol(C'est 100%bolt on a part un trou pour distributeur dans lintake jai la jig si tu es interessé pi une block off plate pour l'optispark avec timming mark pi tu en fait une sur le demper)... Honetement le meilleure chose a faire c'est de tuner ton ECM toi meme, petit a petit, et pi tu va l'avoir le meilleure tune de meme.. C'est ca que je suis en traine de faire et c'est pas facile mais il y'a beaucoup d'information sur cette forum, faut juste lire toute ca. jai pris bpc informations ici mais le fine tunning a distance c'est impossible..je nai plus de check engine tk jaimerait discuter avec toi par téléphone ou directement par chat
fieldy__666@hotmail.com pour msn
450 424 4427 Mathieu.
Old Oct 15, 2010 | 07:22 PM
  #262
boussole's Avatar
Car: 91 ws6
Engine: ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
Transmission: TRANSMISSION, MAN 5 SPD, B0RG WARNE
Axle/Gears: AXLE REAR, 3.42 RATIO
moi ausi je sui a gat et je peut t aider pour de l info ou des piece etc
Old Nov 6, 2010 | 10:32 AM
  #263
1985IrocZ's Avatar
Car: 1985 Z28
Salut tous les Quebecois,
je me cherche une machine shop, beau-bon-pas cher qui peut me refaire les cylindres de mon 350 que je veux virer en 383......a Montreal sont tous trop cher. Peut-etre qu'il y en a des part cher en region???? Merci de votre aide!!!!!
Old Nov 6, 2010 | 01:28 PM
  #264
FOX-GTA_89's Avatar
Moteur National,Atelier Champion,Bhp pi si tu veut pas payer culass express mais je m'abstien de commantaires
Old Nov 6, 2010 | 04:36 PM
  #265
boussole's Avatar
Car: 91 ws6
LAROCQUE ENGINE REBUILDERS
245 COUNTY RD 17
K6A 2R2 HAWKESBURY , ON
Phone: (001) 613-632-0067
Old Nov 7, 2010 | 12:00 AM
  #266
1985IrocZ's Avatar
Car: 1985 Z28
Merci pour vos suggestions, je vais les appeller pour verifier des prix. Mes je suis curieux FOX-GTA_89, pourquoi tu veux t'abstenir de faire des commentaires sur Culass Express.....tu as eu de mauvaises experiences??????
Old Dec 27, 2010 | 08:37 PM
  #267
Pour le club camaro quebec.. comment est ce qu'on peut participer l'annee prochaine?
Old Jan 8, 2011 | 08:31 AM
  #268
boussole's Avatar
Car: 91 ws6
tout vas bien
Old Mar 18, 2011 | 09:49 AM
  #269
Biss'Z28''s Avatar
Car: 1987 z 28
Engine: 308
Transmission: th 350 bm
Axle/Gears: 3.7.3
SALUT LA GANG !!!LE PRINTEMPS EST ARRIVER UNE PETITE QUESTION POUR VOUS,MON 2.8 EST SORTI POUR UN SMALL BLOCK,QUE FAIRE AVEC POMPE A GAZ ELECTRIQUE ? EST CE QUE JE PEU METTRE UN REGULATEUR SUR LA LIGNE PRES DU CARB ? AVEZ VOUS DES IDEES...
Old Mar 18, 2011 | 09:50 AM
  #270
Biss'Z28''s Avatar
Car: 1987 z 28
Engine: 308
Axle/Gears: 3.7.3
SALUT,MOI AUSSI DE GATINEAU !!!
Old Apr 16, 2011 | 07:07 AM
  #271
tazz3871's Avatar
Salut la gang je suis de Gatineau secteur Aylmer j'ai une 87 GTA 5.7 litres
Old Apr 16, 2011 | 07:08 AM
  #272
tazz3871's Avatar
Dans quelle secteur
Old Apr 16, 2011 | 07:12 AM
  #273
tazz3871's Avatar
Hé a tous les gatinois gatinoises peut être que l'on peut faire une rencontre de F-Body une fin de semaine laisser moi savoir
Old Apr 16, 2011 | 10:34 AM
  #274
boussole's Avatar
Car: 91 ws6
moi chu pas pret encore mai le dernier meating a u lieu icihttp://maps.google.ca/maps?hl=fr&q=gatineau&ie=UTF8&hq=&hnear=Gatineau,+Communaut%C3%A9-Urbaine-de-l'Outaouais,+Qu%C3%A9bec&gl=ca&sqi=2&ll=45.504556,-75.677101&spn=0,0.009602&z=17&layer=c&cbll=45.504556,-75.677101&panoid=6Vc0Utx9MsYaqJbACMUeow&cbp=12,92.14,,0,0http://www.boussole.ca/maniwaki.htm
Old Apr 16, 2011 | 11:27 AM
  #275
boussole's Avatar
Car: 91 ws6
une petite nouveauté pour vous http://www.firebreathercar.com/
Old Apr 16, 2011 | 02:41 PM
  #276
FOX-GTA_89's Avatar
si il y as du monde avec des camaro trans am qui veule jaser plus ajouter moi sur facebook
Mathieu Synnott
Old Apr 23, 2011 | 10:01 AM
  #277
tazz3871's Avatar
Hey la gang je vais a Toronto au mois de Juin pour ramasser mon wraparound spoiler pour ma Gta est-ce qu'il y en a de vous qui aurait besoin des pieces a etre ramasser si oui contacter moi sur ce site laisser moi vos coordonner je verifie la board une fois par semaine je vie a Gatineau le plus de gens qu'il ont besoin de pieces le moins cher ca sera pour le transport vous devez commander et payer vos pieces a l'avance je vais chez Paradise a Toronto
Old Apr 30, 2011 | 07:55 AM
  #278
boussole's Avatar
Car: 91 ws6
un nouveau film implique une camaro 2011 http://www.boussole.ca/fire%20breadt...0secret%20.htm
Old Jun 17, 2011 | 07:30 PM
  #279
iroc-z1988's Avatar
salut hi
demeure a sherbrooke
1988 iroc fire engine red convertible all 100% original and its a canadian car ( km)
Old Jun 24, 2011 | 03:13 PM
  #280
Guest
Guest
Posts: n/a
I have the '85 Chevrolet Camaro Z28 305 5 speed. It has the Flowmaster Dual Exhaust(Not True Dual which sucks) but she sounds like a beast and my father has an '87 Pontiac Trans Am GTA All Original(OEM)
Old Aug 10, 2011 | 03:15 PM
  #281
1985IrocZ's Avatar
Car: 1985 Z28
Salut tout le monde! Je me cherche un sub-frame connectors (PEU IMPORTE LA MARQUE) pour ma Camaro 1985 avec un stock exhaust. Si vous en avez un de disponible, appellez moi. 514-966-5774 Jon
Old Aug 10, 2011 | 03:41 PM
  #282
1985IrocZ's Avatar
Car: 1985 Z28
Je me cherche des subframe connectors usagés pour ma Camaro 1985 avec un stock exhaust. Je suis a Montreal. si vous en avez, appellez moi. Jon 514-966-5774
Old Oct 4, 2011 | 09:56 PM
  #283
91z28ss's Avatar
Car: 1991 Z28 convertible camaro
Engine: 383 superram
Transmission: Level 4 Vigilante 3000
Axle/Gears: 3:42,Torsen, moser axles LPW girdle
La saison est presque terminé...Je me souviens d'être allé à l'exposition de Berthierville
au concessionnaire GM il y a quelques années! Estc-ce que ca fonctionne encore ca?? Même à Montréal, il y a pu de rencontre de camaro à la boule orange, seulement des expositions de muscle car ou ''japanese crap''
Infos pour l'année prochaine svp
Gardez notre forum des Québécois vivant
Patrick
Old Apr 26, 2012 | 02:38 PM
  #284
91z28ss's Avatar
Y'a plus personne qui roule un F-body au Québec!?!?!?
Nobody drives an F-Body anymore!?!?
J'ai le moteur original de ma camaro 91 convertible 5.0 tuned port injection complet seulement 47000km
à vendre. Vient avec wiring harness et l'ordinateur avec chip., de la pan à l'huile jusqu'au plenum parfaite condition, aucune bosses sur les runners. Faites votre offre si intéressé. Je vais également vendre mon intérieur complet gris en parfaite condition (sauf les sièges) car je le change en rouge flamme. Également lews kick panels Q-Logic avec des components Éclipse 5 1/4 SC8254... Ainsi qu'un différentiel complet comme neuf powdercoat noir avec essieux Mooser 28 splines, cage Auburn, gear SLP 3:73 et Couvert LPW (main girdle) - de 1000km.
Patrick
Old Apr 26, 2012 | 03:13 PM
  #285
J'aurais peut etre etre interesser a ton kick panels de q-logic.
Et oui c vrai, y'en a pas beaucoup de fbody a montreal MAIS c'est correct pcq ca rend nos autos plus 'rare' hehe!
Je sais qu'il ya un meeting de fbodies a berthierville le 2 Juin 2012. Jvais etre la c sur. C'est la premiere fois que j'y vas. J'ai hate de voir des autres Fbodies de Montreal! (Il y'a plus d'informations au clubcamaroquebec.com)
Old Apr 26, 2012 | 07:03 PM
  #286
boussole's Avatar
Car: 91 ws6
salut hellz wign c est des belles photos pi un beau char me permet tu de publier des chose de ton site a mon site www.boussole.ca Michel gatineau
Old Apr 26, 2012 | 11:06 PM
  #287
Salut Boussole,
Cette annee jvais prendre des photos de mon IROC avec une camera professionelle donc quand c'arrive jvais les poster ici et tu peut les mettre ces photos sur ton site mais ca me derrange pas du tout que tu mettre n'importe quel photos de mon char sur ton site.
Old Nov 30, 2012 | 09:50 PM
  #288
91z28ss's Avatar
Bon dodo pour nos petits bolides, S.V.P. gardez notre tribune Québécoise vivante!!!
May your rides have a nice rest during winter, please keep our Quebec Post alive!!!
Old Dec 2, 2012 | 08:21 PM
  #289
boussole's Avatar
Car: 91 ws6
Old Dec 3, 2012 | 06:41 AM
  #290
sleeper383's Avatar
Car: 1984 Camaro Z28
Engine: 5.0L
Transmission: Heavy duty TH700R4 B&M shifter
Axle/Gears: BorgWarner 9 bolt Ratio 3.45
Salut Tazz,
Comment tu a trouvé ça Paradise à Toronto, ça fait longtemps que je veux y aller mais j'ai jamais pris le temps
Old Jun 16, 2013 | 12:13 AM
  #291
91z28ss's Avatar
Y'a plus beaucoup de monde qui vient ici......
Old Jun 16, 2013 | 11:15 PM
  #292
boussole's Avatar
Car: 91 ws6
Originally Posted by sleeper383
Salut Tazz,
x
Old Jun 16, 2013 | 11:18 PM
  #293
boussole's Avatar
Car: 91 ws6
moi jaimerai deux porte firebird 91 noir
Old Jun 17, 2013 | 09:28 AM
  #294
Oui je viens ici toujours, mais pas sur cette page car il y'a personne qui post ici.. Je suis tres active dans le thread de suspension par exemple.
Old Apr 12, 2014 | 04:15 PM
  #295
91z28ss's Avatar
1 an déjà!!! Je capote ma transmission à encore brise l'an passé depuis mon stroker...La je vais la refaire en stage 4 en commandant un overhaul kit bon pour 750hp et 700 Lbs torque. Avec un torque Vigilante. J'ai hâte à cet été
Old Sep 21, 2014 | 05:48 PM
  #296
SS#1's Avatar
Car: Camaro 1985
Engine: 468
Transmission: Th350
Axle/Gears: Ford 9" 484
Salut les boys je suis de st-eustache j ai une camaro 85 avec le body d'une RS 91 avec un 468 pc forger tout monter roller. Diff Ford 9"
Trans th350. J ai bientôt fini mon projet mais j ai une question ridicule. J ai des mag BBS 3 pièces 20" déçu et je veux les vendre pour du 18". C quoi le offset Max et minimums ?
Merci
Old Sep 22, 2014 | 08:03 AM
  #297
J'espere que t'a mis de connecteurs de frame sinon ton char va casser en deux lol.
A propos de tes mag je me rappelle pas le offset mais 20" sur un 3rd gen c trop large pcq le pneu va etre trop mince.. Le suspension est deja trop stiff et moi j'ai des mag IROC de 16 pouce avec des 245/50/16 la dessus.. Je dirai que 17 c parfait mais 18 c'est vraiment le max que je le mettrai si c'etait moi.
Old May 20, 2015 | 12:55 AM
  #298
91z28ss's Avatar
Printemps 2015 les 3rd Gen se font de plus en plus rare sur les routes...Mais j'ai vu une firebird 1991 blanche convertible en parfaite condition et 1 camaro 1987 avec un moteur 2.8L. Y'a t-il encore des rassemblements de F-body sur l'île ou dans les alentours cette été??????
Old May 20, 2015 | 08:11 AM
  #299
Je ne croix pas qu'il y a des rassemblements mais je conduit encore mon char quelque fois par semaine et j'habite sur l'ile lol. Mais je ne vois jamais des 3rd gen sur la route
Old Jul 19, 2015 | 12:54 AM
  #300
monkey-leader's Avatar
Engine: 6.0L LY6 (Vortech Supercharged)
Transmission: Tick Performance T-56
Montreal, QC
