Keep Blowing fuses
Old Apr 17, 2002 | 12:42 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Keep Blowing fuses
I put in two 12" Alpine Type R's last weekend with a US ACoustics 450 watt amp. I have a problem, a couple of times when I turn it way up, the fuseable link in the power wire burns out. This doesn't happen all of the time when I turn it way up, just twice. I went with a 10-amp and then a 15. What is the problem here?
Old Apr 17, 2002 | 12:54 PM
rkniroc's Avatar
it could be the gage wire your useing. do you have the power wire for the amp goind directly to yhe battery? answer these questions and i could probably help
Old Apr 17, 2002 | 12:59 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
I have 8 guage rockford wire with a fuseable link directly from the battery to the amp.
Old Apr 17, 2002 | 01:25 PM
rkniroc's Avatar
i also use all rockford products it's a good choice the smallest fuse i have on 8 gauge is a 60. for what you are doing it sounds like a 30 would work for you.
Old Apr 17, 2002 | 02:22 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Ok, so the problem was just that I had to small a fuse in there?
Old Apr 17, 2002 | 02:40 PM
rkniroc's Avatar
i think you'll be good to go with the bigger fuse
Old Apr 18, 2002 | 12:24 PM
Matthew 4:19's Avatar
BE VERY CAREFUL!!!!
The fuse at the battery protects your car and you, never, I repeat never use a fuse bigger than the wire guage is rated at, you can get this info from IASCA, this could be a life or death issue. Next the fuse at your equipment is to protect your equipment, never use a fuse bigger than the manufacture recomends, if the propper size fuse is blowing something is wrong. Now what size fuse did you amp come with. Don't hesitate to email me if you have more questions, listed below.
Old Apr 18, 2002 | 01:44 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The problem is you're trying to push subs with an amp that's got a 10 amp maximum rating.
That's sort of equivalent to powering a Bus with a 3 cylinder Suzuki motor from a Metro and wondering why you can't make it up a hill.
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
90formulaVortec
Sep 3, 2015 09:26 AM
