best place to ground amp???/
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Thats where mine is grounded. Just be sure to sand it down to bare metal to get a good ground.
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
That is also where I grounded mine. As a side note, whatever you do, don't screw that amp directly to the floor above the gas tank, as you'll probably puncture it or something. I think there's like 0.25" or less clearance between floor and tank. Mine are now totally out of sight, but I had them there once, and what worked really well for me was that double faced carpet tape. I know it sounds weird, but that stuff worked so good, it was hard to pull the amp off. I know this was off topic, but I just wanted to make sure you knew this.
DUCT TAPE, DUCT TAPE FIXES EVERYTHING!!!!!!!!!
I basically screwed mine into the carpet itself, and didnt go through the floor. jsut use small screws, enough so it wont move.
~Tim
~Tim
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
i used velcro. i was planing on puttin it on the amp and the carpet then i put it on the amp first and set it down to put the strips on the carpet and had to lift the amp to get the perices and the amp was stuck to the carpet so i just have velcro on my amp and it sticks like a ***** to the carpet so no need to use the other side.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
