Where is that hole on the firewall for the power wire?
Old May 11, 2002 | 10:47 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
I had 30 min. before work and couldnt find it.
Old May 13, 2002 | 11:04 PM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
I found one down by the drivers' side pedals (if I remember correctly), under the carpet..there was just some plug there, pulled it out, and voila!
Old May 14, 2002 | 12:41 AM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Just drill one like everyone else.
Make sure you use a rubber grommet or some silicon to seal the hole one the wire is through...
Old May 14, 2002 | 12:57 AM
mudaholic's Avatar
theres a real nice place in the passenger kick.. need to drill, but its quick and easy.. just run it with the big bunch of wires into the engine
Old May 14, 2002 | 06:27 AM
deadtrend1's Avatar
if you have a auto, theres a hole where the clutch would be.
~Tim
Old May 14, 2002 | 07:20 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
There's absolutely NO clutch hole on an automatic. If yours had it, your car had a 5 speed at one time. How do I know this? Because I converted my auto to a 5-speed, and trust me when I say that having that hole would have shaved at least 5 days off my project. The hole I cut looked like something a drunken blind man could have made.
But anyway...
On Camaros, because the battery is already on the passenger side, going through the firewall is by far the cleanest and easiest way to go, although on non air conditioned cars, right under the heater box is pretty easy too.
On firebirds, you're wasting cable by going over to the passenger side, so you should just stay on the driver's side. With an automatic, the area where the clutch master cylinder would reside is a great spot, but like I mentioned above, the hole isn't already there. On 5-speed cars, you can go right under the clutch master cylinder, but BE CAREFUL!! I drilled right into my damned master cylinder. The master cylinder points down at an angle, so even though you think you're safe, you're not. Changing the master cylinder without pulling off the brake master cylinder and booster is a huge pain in the *** until you get the hang of it.
Old May 14, 2002 | 09:43 AM
Azure's Avatar
I know I had a hole (plugged, though), where it would appear a clutch petal would fit perfectly....is it different from Firebirds to Camaros at all...? I can take a picture if you'd like, and I'm positive my car has never had a 5 spd.....
Old May 14, 2002 | 12:02 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
my hole was invisible til my drill made it magically appear
Old May 14, 2002 | 02:01 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Ya I couldn't see mine either, until the drill found it.
Old May 17, 2002 | 05:15 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, I had a hole by the brake booster, that was capped up with a plug, about a 1/2 inch big, I guess? I knocked the plug out with a hammer and punch, and ran my gauge wires thru it. I wonder if the pre-drilled plug "disappeared" (or appeared!) after a certain year of car? I always thought that hole was for a cruise control cable or something, never thought it was a clutch hole.
Maybe if I remember, I'll take a pic of it tonight.
Old May 17, 2002 | 11:10 PM
Jim85IROC's Avatar
the clutch master cylinder hole is about 1.5" by 2" oval shaped. Your hole must be for something else.
The 5-speed cars also have a reinforcing plate around the hole that the autos don't have.
Old May 20, 2002 | 12:12 PM
R.C. Righter's Avatar
Another idea - use the hole where the hood latch cable goes thru the firewall. Just under the relay bank by the master cylinder. If you pull the grommet out, there is plenty of room around the cable. Either modify the grommet, or just leave it open. It's not that much of a hole.
R.C. Righter
2 86 Trans Am's 5.0L TPI
One's fer sale .....
BRoss99
Aug 10, 2025 05:08 PM
Jeremys87
Jul 14, 2022 09:08 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
stalkier
Aug 13, 2015 12:59 PM
ZsTransAm
Aug 11, 2015 07:30 PM
