Experiencing some crazy weird canceling out between two tens, HELP!
Old May 26, 2002 | 10:22 AM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Hey guys,
I just ordered a custom box from ebay for my camaro, it fits two tens and covers the whole well in the hatch. Me and my friend hooked the subs up yesterday, they were both performing to their full potential, and so was the amp, everything was hooked up properly, I assure you. But it hit LESS as hard as my eight inch bass tube. Funny, ain't it? Well for some reason my right 10 went out, and the left one was on, and it slammed more than 4 8 inch bass tubes put together. I then fixed the right sub cuz a wire fell out, and the bass went bad again. The subs were both moving up and down and kicking at a great rate, but I am guessing that either they cancel each other out due to some weird way they are positioned, or the box needs to be ported or the subs have to have their own chamber. They have their own chambers but there is a leak between them. Would sealing them up be of any help? Let me know if u guys have had this problem
Old May 26, 2002 | 03:18 PM
88TAJeff's Avatar
Car: 88 T/A
Sounds like your subs were wired out of phase. That would explain them moving up and down like crazy but producing little bass due to the fact that they are mostly cancelling each other out. Try using the balance control to go right, and then left. If the bass is way less as you get to the middle, they are out of phase.
Old May 26, 2002 | 09:06 PM
Belker's Avatar
Yep! On just one of the subs switch the + to - and the - to + connections (don't worry about how the sub is labeled) and listen. You should have more bass than when just one sub is playing.
Old May 26, 2002 | 10:05 PM
Yeah, that might be it, because tonight I sealed the gap in the box and it still isn't makin much bass. I had the subs cookin today, REAL GOOD, I dunno what happened after that cuz i tried to reinstall the sub in a better position and it got crappy again. All you guys are sayin is to switch up the wires a lil bit? I have the tens wired in parallel (2 ohms). This is a crazy situation, never heard of it before.
Old May 27, 2002 | 01:04 PM
Thanks guys, I got them fired up today, man are they loud!
cheesehomer
Dec 31, 2015 08:48 AM
BrianI
Oct 3, 2015 12:57 PM
drumstixer
Sep 29, 2015 03:02 PM
Zell1luk
Sep 29, 2015 10:36 AM
mfp189
Sep 27, 2015 09:25 AM
