amplifier help
Old May 28, 2002 | 12:59 PM
Ricer Raper's Avatar
amplifier help
i was just wondering if i have an amp that is bridged at 800 x 2 and an amp the is bridged at 600 x 2 can i run two channels to each amp? therefore runnig 1400 watts to each sub? I think the term is dixie chaining but i am not sure.
Old May 28, 2002 | 02:02 PM
pronger44's Avatar
i don't understand what you said if an amp bridged to 800x2 or 600x2 it would have to be a 4 channel amp. if you add all that it would be 2800 watts.(i'm guessing thats max power which isn't veary realistic) personally i wouldn't run two differant amps to two subs though
Old May 28, 2002 | 02:44 PM
mcss383's Avatar
No you can't. Running two amps to the same sub require that both amps are the same make/model and that their gains (and therefore output) are matched exactly. Doing this is rather pointless nowadays...i mean there are plenty of amps that produce in excess of 1000rms, some in excess of 2000rms. Just figure out how much power you need and then buy an amp that will put out that much. The JBL 1200.1 is a VERY good bargain, it puts out a little more than rated and can be had online for ~$280.
Old May 31, 2002 | 12:24 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Sell both of those amps, and buy a quality ("real") 100x2 amp, and you'll be much better off.
SRKLEGIN
Oct 29, 2015 06:38 PM
L98GTA87
Oct 19, 2015 10:43 PM
gta892000
Sep 16, 2015 12:37 AM
84 TA NV
Sep 6, 2015 08:02 PM
