OK? why is my 1000w amp sound like a 200 watter
Old Jun 10, 2002 | 11:42 PM
NEEDforSPEED's Avatar
i have 3 rock for hx2's (1) 2ohm and the other (2) 4ohm all hx2's wirer'd in a 2 ohm load and i have
(2) Infinity digital beta 300 amp's 2ohm load to each chl (500 rms) to each sub.
Sealed sub box was built by me and it has the right -
Recommended volume (Cubic Feet) - 0.75 and a little more then...
so any way i hook't it up and its loud" just not that loud... it sounds like 200 watt's why i dont relly no so thats why im posting this
also
i have a New $329.00 kenwood cd player
i have the bass all the way up and ever thing you can think of is up and i have check all the wireing over and over "is it the amp's??
cuz no one pays (for 1 amp) $699.00 for chrap!?!?"
Attached Thumbnails OK? why is my 1000w amp sound like a 200 watter-camwithnobass.jpg
Old Jun 10, 2002 | 11:48 PM
wires
Old Jun 11, 2002 | 07:09 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
1 sub is a 2 ohm sub and the other two are 4 ohm subs?
Your 2 ohm sub is getting the same amount of power as the other two subs combined. That's part of your problem. Get 3 identical subs, and double check that they aren't wired out of phase. I'd suggest 3 DVC subs, 2 ohms per coil. That will allow you to series-wire the two coils on each sub, then parallel-wire the three subs for a combined impedance of 4 ohms.
Old Jun 11, 2002 | 12:23 PM
they are DVC sub's by the way...
i have all the sub's all wirerd up 2ohm's....
Old Jun 11, 2002 | 01:09 PM
Jim85IROC's Avatar
If one is a dual 2-ohm sub, and the other two are dual 4-ohm subs, then you don't have equal power going to all of the subs, which is a big part of your problem. You should always be running IDENTICAL subs. I'd replace the dual 2-ohm sub with another dual 4-ohm and wire it properly.
I can only imagine how you've got that thing wired. If you've got the coils on the subs series-wired, then all 3 subs parallel wired, you're going to have a 2 ohm load, but because that 1 sub is getting 50% of the power, your output is going to be limited.
If you have all the coils series-wired, and the subs series-wired, then you'd have a 20 ohm load, which would explain your lack of power.
Either way... you need 3 identical subs.
Old Jun 11, 2002 | 05:43 PM
im run 2 subs (the 4ohm's) on one amp
and the other sub (the 2ohm) on the other amp
Old Jun 11, 2002 | 07:14 PM
Jim85IROC's Avatar
In that case my guess is still that one of the 3 subs is out of phase with the other two, or that some of the coils are out of phase with others. You still haven't given me a clue how it's wired, but you should double-check that the coils of each sub aren't out of phase with each other, then you can disconnect 1 sub at a time and see what happens. If it gets louder, the subs are out of phase with each other.
Old Jun 12, 2002 | 12:32 PM
fixt it...
the amp's were not tuned right Frequency (Hz)~ need'ed to be in the midle of 20k - 80k.... proble 27k
wow these f*cker's are violent
not loud but vary violent when your close but when your a block away from the
Z-28 W0W L0UD!!!!!!!!!!!!!!!!!!!! thank's for try'n to help jim i know your vary vary good with sub's, amp's,wire'n. etc.............
sorry for take'n up your time,
Old Jun 12, 2002 | 02:12 PM
Jim85IROC's Avatar
No problem. Glad you got it straightened out. What exactly did you do tho? You have me a little lost. Did you change your crossover frequency or just adjust your bass boost?
Old Jun 12, 2002 | 02:30 PM
mcconahay37's Avatar
Originally posted by NEEDforSPEED
fixt it...
Did you mean between 20 Hz - 80 Hz? Just wondering because 20k - 80k is really high-pitched. Glad you figured it out though. Looks like you've got a good clean install there. I like it.
Old Jun 13, 2002 | 11:28 PM
Looks like you've got a good clean install there. I like it. ........
thanks
What exactly did i do. bass boost,gains, were all f*ck't up like they were backwords or some thing so i tuned them by Ear it worked out good* what do ya think i would hit/spl at Db Drags? just take a gusse no big-E
" all find out in 4 weeks "
Old Jun 13, 2002 | 11:31 PM
mudaholic's Avatar
Old Jun 15, 2002 | 03:53 AM
XxFreeBirdxX's Avatar
Red wires on right of pic #3 -
Please don't tell me these (what looks to be) 3 tiny little wires
are your power wires.. If so, you really should get 1 MUCH bigger
wire. Such as like 1/0Gauge or 2Gauge..Just a thought-
Old Jun 15, 2002 | 04:28 PM
) 3 tiny little wires...........
naw........
(4) 40amp wires put the (2) from one amp it makes 4gauge big deal i know what im doing
the amp's are 80amps
there are two power wires going to the amp's and two ground's
Old Jun 15, 2002 | 08:05 PM
1: can you try saying this a little more intelligently? because i can't
understand wtf this is supposed to mean. also, you don't have
to be an a$$ about it. "big deal i know what im doing"
2: 40amp wires? do you know what you're talking about?
3: lots of small wires won't do the same as one large wire.
db057
Jan 10, 2020 08:55 PM
gta892000
Aug 11, 2019 11:16 AM
HP52TA
Feb 3, 2018 10:51 PM
gta892000
Sep 16, 2015 12:37 AM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
