My amp is a solar powered meat thawer! Does it hurt it?
Old Jun 11, 2002 | 09:04 PM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Hey guys,
After sitting in school all day in the heat, I cranked the system when pullin out of school today. But I could smell the stuff burnin in the back. It gets really hot from sitting in the sun UNDERNEATH my cargo cover. My amp gets hot, nothing else. When I crank it, it again gets hot. I wanna know how hot can it run before I start to hurt it. It gets hot whenever I fire up the car and the stereo is on, period. Its all hooked up fine, but its a 150.2 pushin 2 10s, it hits. Its at half gain, three quarters bass boost at 12db. Its wired in stereo at two ohms (2 ten inch DVC subs) It gets so hot that I burn my hand on it sometimes.
Old Jun 11, 2002 | 10:09 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Most amps have thermal protection built in to prevent them from being damaged by overheating. So if it gets too hot, it may either shut off completely or reduce power output.
Old Jun 11, 2002 | 10:14 PM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
What gauge power wire are you running to it, 2 ohm stereo is alot of current, it should be ATLEAST 8 ga. but most likely needs to be 4 ga. What brand is the 150.2?
When an amp is currnent limited it will heat up more, and if your burning yourself on it I'd say that's WAY to hot! :nono: :nono:
Old Jun 12, 2002 | 07:20 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
heat kills electronics. There's no telling what temp will instantly kill it, but any temp will cause it to fail over time. Raising the average temp of an amp by 10* shortens it's life by half.
Old Jun 12, 2002 | 10:52 AM
underdave's Avatar
Car: '91 Firebird vert
Engine: 305 TBI
Transmission: auto
i met a guy once that put a small fan in his amp somehow. he said it worked good, it was like a 1000 watt amp and he said it stayed cool. i'm sorry but i have no idea how he did it, but it might be something to look into.................
Old Jun 13, 2002 | 02:10 AM
pronger44's Avatar
you just buy a 12v fan and run it off the power circuit in your amp
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
sailtexas186548
Aug 24, 2015 10:11 PM
InfinityShade
Aug 22, 2015 08:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
