Deck isn't working
Old Jun 19, 2002 | 12:45 PM
THEISENATOR's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Deck isn't working
Alright, I was hooking up an amp that I found for $25 bucks, an Orion Cobalt 420. I was hooking it up to my JVC El Kamilion deck. Both the amp and deck were working fine, but then I hooked it up to my JL 12W3 sub to see how the amp would push it. The amp had power, then I plugged in the RCA cables. It worked for a couple seconds, then the deck started turning on and off again. Finnaly it just shut down and wouldn't turn on again. I checked the fuse pannel, and the fuse is good. Then I checked both power wires, they both have power. Is there an internal fuse inside the deck that might be blown? I didn't see one on the outside. Oh, one more thing I will add. I just put in this high pass blocker that I bought at a local electronics place that blocks anything above 100 hz. Because the amp didn't have anything that will block the high stuff.
Old Jun 20, 2002 | 09:49 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
There is a fuse on the radio. Take out the harness and there will be a 15A fuse there. A don’t think this is your problem.
Jorlain
Aug 24, 2022 05:11 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
mustangman65_79
Car Audio
Sep 30, 2015 09:37 PM
Fronzizzle
Aug 9, 2015 01:15 PM
