box Question
Old Jul 19, 2002 | 11:07 PM
pandorafowler's Avatar
Car: `91 rs
Engine: 352 TPI
Transmission: TH700 R4
box Question
Would having my 2 subs firing down into the 31x12x8 area make it hit harder or just muffle the sound? Also would it damage the subs firing down into a small area like that or should i run a port from down there going up?
Old Jul 22, 2002 | 01:49 PM
88formla350's Avatar
Im thinking about putting 2 10"s in a sealed box down in the well, but I was also wondering if that is big enough. Surelly some one has done this. Thanks
Old Jul 22, 2002 | 02:18 PM
87350IROC's Avatar
Car: 87' IROC
I think one 10 or 12 would be ok, but i don't think there would be enough room for two. Maybe two 8's.
Old Jul 22, 2002 | 04:41 PM
82Z28_Camaro's Avatar
Facing them down increases the db's by 4. I have actually tested this at my local car audio store.
- Colby -
Old Jul 25, 2002 | 02:18 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
That sounds ridiculous. Db's are measured by Sound Pressure Level. You're not going to compress the air in the inside of the car any more or less by facing the subs a different direction.
Old Jul 26, 2002 | 12:14 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
I put two cerwin hed 10s in a small truck box, the triagle kind. I think they could sound better in anything else. Sure they bass but I'm not giving them what they need.
Old Jul 26, 2002 | 08:58 AM
Polecat's Avatar
- Colby -
Whomever told ya that is wrong, and just needs to learn somemore.
SPL is pressure measure at a certain point, dash, kick panel,port,etc.
pandorafowler I see in your sig you have S12c's...if so, they need to be in a .88 sealed. Not ported. Those woofers were designed for small sealed applications, not ported.
Old Jul 26, 2002 | 04:50 PM
Car: `91 rs
Engine: 352 TPI
Actually for what I`m pushing, they need to be in a .66 sealed box. I went and built a box for them that fit into the small space and have them fire into the back of the car. They are definatly hitting harder than when they were firing upwards.
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
redmaroz
Aug 16, 2015 11:40 PM
