two amp wiring questions
Old Aug 6, 2002 | 07:53 PM
CaysE's Avatar
1st question: How should three amps be wired to the remote wire (turns on the amps when H/U is turned on) on the headunit? Should I do it in series from one amp to the next or splice the wire midway and run it to all three amps?
2nd: Anyone know a good way to get a power wire through the firewall? Are there any openings already there? I really want to avoid drilling if I can help it.
Thanks for any help
Old Aug 6, 2002 | 08:48 PM
mudaholic's Avatar
1) generally your headunit can support 3 amps on a remote lead, but to be safe you might want to just wire it to a relay...
2) pull off your passenger's kick panel and your fender guard thing on the front passenger wheel; you can drill through there, but check for clearance before you do anything.. install a gromet and you're good to go!
Old Aug 7, 2002 | 12:17 AM
CaysE's Avatar
I'm not familiar at all with relays. How does that work?
Old Aug 7, 2002 | 12:43 PM
mudaholic's Avatar
check this site out; great explanations
Old Aug 7, 2002 | 03:03 PM
CaysE's Avatar
wow, kick *** site! thanks a ton, this one's going in the favorites
Old Aug 10, 2002 | 11:15 PM
drewkivela's Avatar
i ran a 4 ga and an 8 ga by the steering column, plenty of room
RazorN8
Jan 7, 2022 11:44 AM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
ZsTransAm
Aug 11, 2015 07:30 PM
