Trouble fitting 4x6's in my Z28
Old Aug 11, 2002 | 12:16 AM
GoldenSwordZ28's Avatar
I realize that theres a tech article for this and all, and have read it. But for my problem it seems a bit extreme. The problem that I'm having is that I can't my Inifinity Refrence 4x6 on the Drivers side to sit properly, the magnet is touching the back of the Control closter it looks like. I was figureing that it may be possible to get a spacer to make up for the space since its not to large of an area that its spaced out by. If theres somthing that I can purchase that will fit in there I'd like ta know, or if anyone has other ideas I'd like them as well
Adam
Old Aug 11, 2002 | 12:45 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I had to cut some of the plastic back there to fit in my Inifinity Kappa plates.
Old Aug 11, 2002 | 11:31 AM
camaro6spd's Avatar
firebirds have smaller space for the 4x6s in the dash, I put in Kappa plates and all i did was put 3 washers between the speaker and the mounting plate and shaved a little bit of the under side of the dash pad and all is well....screw cutting up your dash if you a camaro.
Old Aug 12, 2002 | 01:46 AM
91-Z-Speed's Avatar
I put in some Boss Audio 4x6's in there and they sound great, esp. because of the 300w max and 150 normal operating range , but I have to retighten the bolts every 2 months because the speakers knock them loose :P
Old Aug 12, 2002 | 04:54 AM
zer0321's Avatar
that's strange; mine (kappa 462.3cfp's) plates fit in there perfect with no chopping/hacking whatsoever!
I had the same problem in my old car; a couple of "lock washers" from your neighborhood hardware store should easily fix your problem.
When all else fails.....BRUTE FORCE PREVAILS! lol
CarGuyDennis
137
Dec 6, 2016 11:02 PM
evilstuie
Apr 14, 2016 08:52 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
