Battery Replacement...
Old Sep 8, 2002 | 12:44 PM
IROCKER's Avatar
I know this is not specifically a audio question, but I figured you guys would be more appropriate to answer this question. My battery just died yesterday and I was thinking of replacing it with a deep cycle battery instead of the regular AC Delco that I have in there now.
I was thinking of getting an Optima battery (yellow top) but someone also suggested I look into a marine battery instead. Does anyone have any comments or suggestions on this? Your input would be very much appreciated.
Old Sep 9, 2002 | 07:31 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I've been using an Optima yellow top Deep Cycle for over 6 years now without any problems. I had to get a little creative with mounting it though. Seems the little block used to hold the standard battery down doesn't quite fit.
Old Sep 9, 2002 | 04:22 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Optima's made by Interstate; http://www.ibsa.com/www_2001/content...ery_optima.asp
Plus, Interstate & Diehard batteries are stronger than the AC Delco you had... as battery technology improves, so do the CCA's. Avoid cheap batteries like Walmart or Kmart or Pep Boys or Autozone or etc; these places put their own label on a cheap (like Exide) battery. In fact, look at a battery like a Pep Boys "Pro-Start" and you'll find "manufactured by (someone else)" in small letters on the sticker.
Sears and AC and Interstate are the only companies that sell their own batteries; you really can't go wrong with them.
Old Sep 11, 2002 | 12:15 PM
CaysE's Avatar
If you have a lot of engine mods done, you don't want a Yellow top, unless you plan on running two batteries. The Yellow top has around 550 cold-cranking amps; most likely less than the Delco you had in there. Start with a Red top 75/35. They're cheaper, have 700-something CCAs to start your engine up right, and will run much better than the Delco. As your stereo system grows, invest in a dual-battery set-up, in which case you run a Yellow top for the system. If you have an amp powering a sub or two with aftermarket speakers and headunit, the Yellow top is really just a waste of money. The Red top can handle being deep cycled once in a while, much better than a Delco can. Hope this helps.
Old Sep 11, 2002 | 07:49 PM
camaro6spd's Avatar
I put a Wal-Mart Everstart Maxx with 950 CCA.....works fine for me and Wal-Mart batteies are rated very good by consumer repors
Old Sep 13, 2002 | 10:08 PM
caleb's Avatar
Car: 89' Iroc
ya i bought that wal-mart dura-something for $60 puts out 1000 Cranking amps, and 900 CCA, i havent had any problems with it yet, but i dont have my stereo in yet, so it hasnt been hard on the battery, but its got a 9yr warranty
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
