i need a diagram please
Old Oct 5, 2002 | 06:06 PM
White Ninja's Avatar
ok, since everyone so-very much recommends the JBL1200 to power my 2 DVC alpine Type Rs instead of a 2channel amp....could someone please give me some wiring diagrams? i'd very much appreciate it. thank you.
Old Oct 5, 2002 | 10:18 PM
mcss383's Avatar
Do you have the dual 2-ohm or 4ohm model?
Old Oct 5, 2002 | 11:28 PM
92 z28's Avatar
you get more power out of parallel setups.
Old Oct 6, 2002 | 01:37 AM
dual 4 ohm... so the end result will be 1ohm.
Old Oct 6, 2002 | 08:30 PM
CaysE's Avatar
This should be it right here. It all comes down to single channel 1 ohm operation on the amp. Of course, the single red line on the left goes to the positive on the amp, and the single blue line on the right goes to the negative.
Old Oct 6, 2002 | 08:40 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
this may be a bit confussing but i think its a little easier to understand than CaysE's.
File Type: bmp
Old Oct 6, 2002 | 10:35 PM
thanks guys. The exterior wiring for the JBL1200 is gonna just look like 2 DVC subs wired in parellel to each channel.. but the amp is 1 channel and will see a 1ohm load... thank again!!
- Andy
Old Oct 8, 2002 | 08:32 PM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
I'm still trying to decide between the JBL1200.1 or the Audiobahn H1300HCQ. Same output at 1200.1 x 1 ohm, but the audiobahn is $360 and the JBL is $285 but the Audiobahn looks so much better than the JBL....GGGGGGGRRRRRRR!!!!!!!!!
Old Oct 8, 2002 | 09:25 PM
92 z28's Avatar
id say audiobahn is better.
Old Oct 8, 2002 | 09:51 PM
audiobahn'll probably give you a little mroe quality and stability, not to mention a more well known name... but i'm just not rich enough to shove out another 100 bucks for the same thing... i dunno....
InfernalVortex
Apr 20, 2021 11:31 AM
SavingPvtEric
Sep 29, 2015 05:59 PM
tattmann
Sep 27, 2015 05:20 PM
wstephan96
Sep 25, 2015 04:28 PM
timonator
Sep 11, 2015 05:11 PM
