HELP....................NO Dash lights........tried installing headunit....
Old Nov 2, 2002 | 08:51 PM
FLYNLOW92rs's Avatar
Old Nov 2, 2002 | 09:08 PM
miked's Avatar
Let's start with what wires did you use when you hooked up your deck. In my car I used orange for the 12 volt constant, yellow for the switched lead and made my own ground. I'd start here and see how you hooked the deck up. A test light would be handy to have as well.
Old Nov 2, 2002 | 09:41 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Is it just the dash lights or all lights like parking and headlights? Sounds like you might have hooked up the dimmer light to deck wrong.
Old Nov 2, 2002 | 09:58 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Yeah, check that out.
Didn't you use a wire harness?
I would also sugest just runing a line from your battery. It is less strain on you acces, wire.
Old Nov 2, 2002 | 10:12 PM
Old Nov 2, 2002 | 10:15 PM
Old Nov 2, 2002 | 11:30 PM
Originally posted by FLYNLOW92rs
I connected the yellow and red wire from the deck to the red wire from the factory wire.........
Why did you connect 2 deck wires to 1 car wire?
Old Nov 2, 2002 | 11:33 PM
miked's Avatar
Hook it up the way I suggested earlier and then try it. Just hooking up wires at random can cause problems like you suggested. I wouldn't be surprised if some of what you thought were speaker wires might be power wires and that is contributing to your problem. Use a test light and make sure before you hook things up.
Old Nov 2, 2002 | 11:36 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Ya you connected ther two togheter, that is causeing part of your problemmmmm
Old Nov 3, 2002 | 02:50 AM
Old Nov 3, 2002 | 03:06 AM
The deck unit won't turn on when i connected the red wire and yellow wire seperate.......
Also the headunit works, just not the dash lights........
Also it resets and gets no power when the car is off...........the settings reset everytime.....
The reason it resets is because you have the 2 wires hooked together. One wire is for the switched cct, while the other is for a constant hot cct. Don't know the color codes off hand, but they have been posted on the board several times recently. There is a reason that those wires are seperate, unhook them now!
Old Nov 3, 2002 | 03:10 AM
Old Nov 3, 2002 | 03:38 AM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Connect the Red to the orange wire in the above diagram.
That is a constant hot in our cars. It's the accesory wire.
That will store all of you settings, and everything else.
The yellow can go to your fuse box, there is a spot in there for the radio, it is marked.
Once you do that everything should work right.
Get's tohse wires disconneted though, that could cause problems...
Old Nov 3, 2002 | 03:49 AM
Old Nov 3, 2002 | 03:59 AM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
No, sorry.
Old Nov 3, 2002 | 10:26 AM
CaysE's Avatar
Wha? yes there is. Connect the Yellow wire to the Yellow wire in the diagram. Connect the Red to the Orange. Done.
Do you have the diagram that the headunit manual has in it? That would be better to look at. What model is your headunit?
Old Nov 3, 2002 | 02:29 PM
Old Nov 3, 2002 | 03:23 PM
CaysE's Avatar
The yellow wire is probably grounding itself. Just take it out and cover the wire with something (BAD flynlow, BAD :nono: ). That should solve your problem.
Old Nov 3, 2002 | 03:27 PM
Old Nov 3, 2002 | 03:32 PM
CaysE's Avatar
LOL... you're having some bad luck with this install aren't you? Well, hindsight's 20/20, and lesson learned: never rush so much that you leave wires exposed.
The only other fuse I can think of is the accessories fuse on the fuse block. Check that one. You might have a fusable link on the yellow wire, depending on the headunit, also. If all else fails, have an audio shop open it up and see if you fried anything. It's possible there's another fuse inside the unit, but you could potentially void a warranty if you check yourself.
Old Nov 3, 2002 | 03:36 PM
Old Nov 3, 2002 | 03:38 PM
CaysE's Avatar
I installed my headunit today, and pondered getting rid of the factory harness. But I thought of the poor guy trying to put a different head unit in next time...
...Which will probably be me and some sweet-as-hell Clarion.
Old Nov 3, 2002 | 04:05 PM
Old Nov 3, 2002 | 04:11 PM
CaysE's Avatar
Haha... I don't even think I'd tackle an alarm system. Too much crap to worry about.
Good to hear it works now. SEEYA
Old Nov 3, 2002 | 05:03 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Jeez man, I know how it feels.
When I first started doing this stuff, I had a hard time to.
But you will ned to do a little wireing for the Guages.
When you get ready to do it, I will take you thur the steps.
DONT READ THE PAPER OF INSTRUCTIONS THAT SOME WITH THE GUAGES, SOME OF THEM DONT MAKE SENSE, AND WILL MAKE YOU MORE CONFUSED....
Old Nov 3, 2002 | 10:23 PM
Old Nov 3, 2002 | 10:48 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I e-mailed the guy cause i can just buy them from him for $50 since the auction already was won with the Buy-It-Now price........
So if we will sell them to me off ebay.com i will be owing some too........
When i get them, I will let you know, cause i will need your help hooking them up, Electronics are not my area..............thanks..............
It's a lot less wires than the stereo.
So it wont be too hard.
But there are alot of screws the hold the dash in.....
Jorlain
Aug 24, 2022 05:11 PM
rocn7roc
Sep 21, 2021 02:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
