1991 Camaro Screw problem
Old Nov 4, 2002 | 06:40 PM
91RSGYEA's Avatar
i am having problems with getting the screws out on the top of the dash.......the windshield is in the way and i cannot get a grip on the screw/bolt because of it.........any tools that would do this? any tips would be appreciated thanks
Old Nov 4, 2002 | 08:39 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
i just used a screw driver for my screws. if you have the hex ends you could get an adapter to go on an electric screwdriver or one of those hand-held ones that you can put different bits on.
good luck,
jacob
Old Nov 4, 2002 | 09:03 PM
91RSGYEA's Avatar
neither........like little bolts.......just can't get to em with a socket it is driving me nuts!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.............i need to change my 4x6's
Old Nov 4, 2002 | 10:43 PM
camaro_60181's Avatar
Car: 1986 Iroc z28
Just take a 9/32 (I think)1/4 drive socket and a 1/4 inch drive extention. you shoud have no problem. I just did mine and i had bolts too...
Old Nov 4, 2002 | 10:51 PM
FLYNLOW92rs's Avatar
You need an extension........That's what i did too......
Old Nov 4, 2002 | 11:23 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
It's 5/16" I think.
Anyway... a U-joint does wonders also. And word from the wise, get a magnet nearby so you can grab the screw BEFORE it falls into the defroster vents.
AJ
Old Nov 5, 2002 | 08:44 PM
SlowMaro's Avatar
yes yes a magnet is needed
Old Nov 5, 2002 | 09:00 PM
91RSGYEA's Avatar
i already tried the extension i can't move the socket b/c of the window tho.......IT IS DRIVNING ME KNUCKINFUTZ
Old Nov 5, 2002 | 09:02 PM
SlowMaro's Avatar
ratchet with a pivoting head should do it man.....or go to the store and buy a carb tuning screw driver, its like a long *** spring connected to a handle, ...kinda weird to use for the job but itll work lol
jhawkeye
May 25, 2022 06:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
TheJoeY88
Aug 13, 2015 06:51 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
