What do I do with this?
Old Nov 5, 2002 | 07:37 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I am wanting to pull my factory speakers outta the sail panels and replace them with better ones. I removed one of them and there was this connector connected to the speaker, do I cut it and then just wire it up the other speakers? How will I know what wire is what? or do they make a connector for the new speakers so then I can still use this? I am going to buy some new ones tomorrow...HELP!!!!
Old Nov 5, 2002 | 07:38 PM
whoops forgot the pic.
Old Nov 5, 2002 | 08:02 PM
SlowMaro's Avatar
cut n splice, .....grab a voltmeter *multimeter* and figure out whats pos and whats neg. not that it matter a whole lot, ...even wired backwards itll work if you plan on ever putting the factory speakers back in, cut it to where you have enough slack to wire the harness back on .....easy simple fun, do it to it. if you need help putting 4 12's in the back of a camaro and keeping the rear seats , ....i can do that too lmao
Old Nov 5, 2002 | 08:04 PM
Nope not planning on puttin the factory crap back in....Its my car and Im never gonna sell it...I'll just sell all the stuff I pull out to someone who may want a factory stereo and speakers...
Old Nov 5, 2002 | 08:35 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
They make connectors that plug into the stock harness. Places like Best Buy should stock them.
Old Nov 5, 2002 | 08:37 PM
SlowMaro's Avatar
to hell with the harness, thats money wasted, ...cut n splice my boy, ..cut n splice.....prolly be harder finding the damn harness than actually cutting the wires....just cut the @#$%ING wires!! lol.....
Old Nov 5, 2002 | 08:39 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I just did a search for you with "GM" as the keyword and I found this ........
GENERAL MOTORS
P o w e r
Memory (+12v Constant) Orange
Ignition (+12v Switched) Yellow
Ground (-) Black
Illumination Gray
Dimmer Brown
Power Antenna Pink
S p e a k e r s
Right Front (+) Light Green
Right Front (-) Dark Green
Left Front (+) Tan
Left Front (-) Gray
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Left Rear (+) Brown
Left Rear (-) Yellow
AJ
Old Nov 5, 2002 | 08:40 PM
SlowMaro's Avatar
ah hah! there ya go, ...cut n splice!! its free and easy!
Old Nov 5, 2002 | 08:57 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
I cut and spliced when i put some pioneer 6x9's in there they sound great and i shoved all the splicing behind the speaker so it looks really good even though the interior panel will cover it
Old Nov 5, 2002 | 09:44 PM
cut & splice it is...I guess...how many wires are in there? they should be the colors of what AJ_92RS found...right?
thanks by the way, RJ..
Old Nov 5, 2002 | 09:45 PM
SlowMaro's Avatar
2 wires......check that color code even though it wont matter that much, itll work either which way, ....not like you are running massive impedance loads
Old Nov 6, 2002 | 06:46 AM
SuPeR SpOrT's Avatar
this is what I did and it works amazingly and you don't need to cut anything....
I ripped the other connector off of my old stock speaker adn tehn I got two other speaker wires taht I had lying around and cut them so they were about 10 inches long... tehn I soldered the wires to the old connecter that was on the stock speaker, then I wrapped the other end of the wire around the terminals of my new speakers then I went to my car and pushed in the connector to teh other connector, installed the speaker and POW it worked...
And you don't ned to worry about ripping anything apart (accept for the ****ty stock speakers.
Old Nov 6, 2002 | 07:33 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
cut & splice sucks. That wire is short enough already. You can buy little t-connectors that you connect to individual wires (under the plastic sheath), then plug a male quick-disconnect terminal into. clean and effective, and you can easily put the stock speakers back in at any time.
t-connector:
Disconnect that plugs into it:
Old Nov 6, 2002 | 08:11 AM
Jim, where do I get that stuff? and what do I ask for?
Old Nov 6, 2002 | 11:14 AM
White Ninja's Avatar
i agree cutting and splicing sucks.
- Andy
Old Nov 6, 2002 | 12:03 PM
Jim85IROC's Avatar
Anywhere. Even Wal mart has it!
Old Nov 6, 2002 | 02:26 PM
joshp14's Avatar
The connector that you are looking for is sold by <A HREF="http://www.crutchfield.com">Crutchfield.</A> Just give them a call and say you need the rear speaker harness/connectors for an 87 IROC (or whatever car you have) and they will send them to you in a couple days. It was like $5-10 for the pair w/shipping. All it does is plug into that connector and then connects to your new speakers. It will save you from cutting and splicing and working with those dinky a$$ stubby wires.
Old Nov 6, 2002 | 02:47 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Just remember which wire is which when you wire the new speakers in. .... Make sure that the neg. is with the neg. and pos. with the pos. on both sides....
Otherwise the speakers will be out of phase and not give the same sound quality.......
Like other people have said, you can also wire the pos. to neg. and neg. to pos. Just as long as it is the same on both sides of the car, so pay attention!!!
Cutting and splicing sucks, but it works for less than 10 bucks!
Old Nov 6, 2002 | 04:09 PM
after thinking about it, I really didnt want to cut/splice the wires so I went and got these from Circuit City......they were only $7....I didnt mind spending the money......
Old Nov 6, 2002 | 05:18 PM
joshp14's Avatar
Thats exactly what i was talking bout. try to keep it neat...for $7...thats only 140 pop cans (if you have a deposit in NC).
Old Nov 6, 2002 | 05:43 PM
Thats how I got...I walked aorund and collected the cans till I got enough for the connectors...NOT!!! Thats funny though....I think they quit the deposit stuff..... dont know..its been awhile...since I was a kid..:sillylol:
Old Nov 6, 2002 | 06:01 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
These are what I used.
They plug right in to the adapter that is there...
