What do professionals use to carpet sub boxes?
Old Nov 11, 2002 | 11:43 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
yea, i was wondering something. does anyone know what professionals use to carpet sub boxes. i have the material and i was just wondering if anyone kne wif they used liek spray adheasive, staples, tacks or what.
Old Nov 11, 2002 | 11:58 PM
FLYNLOW92rs's Avatar
They use an adhesive, they don't use tacks or staples
Old Nov 12, 2002 | 01:36 AM
TrueBlue91RS's Avatar
3M makes a product called 'High Strength 90 Spray Adhesive.' It's easy to use, pretty damn strong, and bonds carpet to MDF and fiberglass effectively. Should be in most larger hardware stores.
Old Nov 12, 2002 | 02:20 AM
HamSpiced's Avatar
my next question is, how exactly does one carpet a box, is ther a general rule to it, is it one continuous piece or does it overlap in places? does anyone have a certain design or pattern to follow a rule even?
Old Nov 12, 2002 | 08:19 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Practice. There's no patented way to carpet a box. You definately don't overlap though. Use common sense and make sure that you put your seams in the most inconspicuous spot (i.e. not on the front of the box). After you do a couple hundred you'll get good enough to make the seams invisible.
Old Nov 12, 2002 | 08:09 PM
SlowMaro's Avatar
try running over the seams with a knife, ....kinda likea scraping motion, itll rough up the carpet and you wont see the seams....
Old Nov 12, 2002 | 10:31 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
when i did my box, all i covered was the top of it (whatever was seen) and used a single continuous piece. no need for multiple pieces
Old Nov 12, 2002 | 10:33 PM
SlowMaro's Avatar
i second that, why carpet the parts you wont see
Old Nov 13, 2002 | 07:24 AM
Jim85IROC's Avatar
True. On a thirdgen box you can get off easy by just doing the top part, but with more conventional trunk boxes, it's going to require some more work.
Old Nov 13, 2002 | 11:41 AM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
On boxes that have multiple sides that will be seen, I have always sewed the seems together. Nothing fancy, just stitching them up so that way in the future when you can normilly see some mdf you wont. It is not a needed step but it turns out nice and only take a couple of minutes.
Brian
Old Nov 13, 2002 | 04:58 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
Brian
that sounds like a pretty good idea. never thought of that.
yeaaaaa, my 200th post. go me. my next goal....catching mr. shields.
Old Nov 17, 2002 | 01:35 PM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
let two pieces overlap, then take a razor blade and cut through the two pieces where they overlap, making sure you are cutting both pieces, giving you two pieces that fit exactly together
Old Nov 17, 2002 | 05:19 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
first rule is use lots of sharp blades prefferably carpet blades, they are double sided and easier to handle, try to use a continuious piece and put your seam on the bottom of the box, and try to keep enough excess on the side so you can cut a flap that is connected on top and seals on sides and bottom. also 3m 90 adhessive spray works best
Old Nov 17, 2002 | 05:40 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Maybe if you carpet the whole box, the places where the box hits the plastic wont rattle as much? ionno..
$750 L98
Feb 1, 2025 02:25 PM
Ed1LE
Sep 30, 2018 09:14 AM
Zell1luk
Sep 29, 2015 10:36 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
indygene
Sep 26, 2015 11:21 AM
