Eninge noise through AMPS HELP!!!
Old Nov 26, 2002 | 12:20 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I put my new install kit in today i ripped out the 8 Guage and put in 4 Guage. Well after i was all done i still have the same enigne nosie i had before any ideas how to cure this i think it might be comming from my MSD 6AL my CB also makes the same noise my stereo is makeing the cb has been makeing the nose since i purchased it. Is there any way to get rid of the noise? I have both amps grounded to were the big bolt that holds the rear seatbelt in. Its a Shoulder belt and the grounds are only 2 feet long for 1 amp and 1 foot for the second amp. I hope i gave u all the information to help me.
Old Nov 26, 2002 | 12:30 AM
9177's Avatar
Get a noise filter and hook it up to the MSD box. Get it as close to thebox as possible. I had to do this with mine and it got all the noise out. MSD makes one but I just got the biggest one they had at radio shack and used it.
Old Nov 26, 2002 | 02:29 AM
FAST RS's Avatar
What exactly did you get at radio shack? Just a noise filter?
Old Nov 26, 2002 | 07:36 AM
fly351's Avatar
Car: 1996 Camaro RS
Engine: v6
keep your ground wire under 18 inches if possible.. it helps.
don't run your ground and power along side eachother.
don't run your speakers and power wires next to eachother. Crossing on a 90 degree angle is ok.
-fly
Old Nov 26, 2002 | 08:51 AM
9177's Avatar
ya I just got a noise filter 30 amp I believe and hooked it up as close as possible to to box. I first found out it was the box by disconnecting it.
Old Nov 26, 2002 | 01:55 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Is the place where your ground wire is connected bare metal or painted? You may wanna sand it down if its painted to get a better ground "connection".
Old Nov 27, 2002 | 11:31 PM
My84TA's Avatar
Car: '84 Trans Am
Engine: 305 H.O. Edelbrock 600cfm, XE262, ported L69 heads, Hooker cat-back
The main thing that causes noise in your system is running
your RCA's and power wires together. Make sure you run them
on opposite sides of the car. Hope it helps...
Old Nov 27, 2002 | 11:34 PM
FAST RS's Avatar
Ill try that next weekend when i get a day off again i got the MSD Noise suspressor from work tonight so im gonan put that on when i get a chance. I hope it helps.
Old Nov 28, 2002 | 07:29 AM
9177's Avatar
Try that first I think that should work if its the part I think it is.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
sjorgens
Oct 1, 2015 07:54 PM
raymondandretti
Sep 27, 2015 06:43 PM
