Batteries!!!!
Old Dec 12, 2002 | 09:09 PM
1982chevycamaroz28's Avatar
Batteries!!!!
Well tonight i was playin my system and well the battery power got kinda low, lower then normal. and i was woundering sincei dont have a cap. , should i upgrade to a better battery? i was thinkin of tryin one of those Optimum yellow top batteries. becuz right now i have a small penseky battery that ive had for about 2yrs. what do u guys think?
Old Dec 12, 2002 | 09:27 PM
SSaudio's Avatar
def upgrade. Having a better batt will never hurt you. I have a red top in my car. It's great with the system as far as drain is concerned.
Old Dec 12, 2002 | 09:38 PM
okay kool thanx.
Old Dec 12, 2002 | 09:44 PM
mudaholic's Avatar
are you talking about playing your stereo with the car running? if so, a better alternator--not a battery--will alleviate your problem. better (or more) batteries will allow you to play your system for longer with the car turned off (when the alternator isn't supplying VOLTAGE ), but for while the car is on a higher output alternator is probably what you're looking for.
Old Dec 12, 2002 | 09:57 PM
oh okay, yeah when i was coming home from work tonight thats when it kinda got low like at the 13 mark on the camaro gauge but normally its about 1/4 of an inch above the 13 on the gauge.
should i just buy a brand new AC DELCO alerternator from the dealership? or could i just use a new one?
Old Dec 12, 2002 | 10:58 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
it doesnt sound like you really have a big problem there. a cap would probably do the trick. 0.5-1.0 Farad should be plenty fine. also, i agree w/ ssaudio, a batt upgrade would not hurt a bit. and as mud said, a alt upgrade will not hurt. any of the 3 would satisfy what ails ya.
Old Dec 13, 2002 | 08:30 AM
9177's Avatar
I would look into an aftermarket 140 amp alt. I have not beed to impressed with the durability of a gm unit with a decent system in it. For $100 from summit look for an Iceburg conversion kit, I think thats the name, anyway I have one and had no problems.
Old Dec 13, 2002 | 08:52 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
1982chevycamaroz28 Have you ever thought of a second battery with a isolater to charge both batteries? Just a thought.
Old Dec 13, 2002 | 01:53 PM
mudaholic's Avatar
two batteries will increase the load on the alternator, and give you more voltage drop problems--great for playin your system when the car is off, but more strenuous when the car's running.
Old Dec 13, 2002 | 02:10 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Actually the isolator only allows one battery to charge at a time. If you hook up two batteries by them self then yes it would be bad for the alternator, again that is what the isolator is for.
Old Dec 13, 2002 | 03:17 PM
SSaudio's Avatar
I happen to have a stinger SR200 bat isolater here f/s for $50, New IN Box. Just in case
Old Dec 13, 2002 | 08:03 PM
mcss383's Avatar
But it still has another load to deal with. True its not at the same time, but it is another load and will not help with small voltage changes.
Old Dec 13, 2002 | 09:39 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Somewhat true. But you run the car off one battery and the system off the other. I ran a system in a 90 Cavalier Rs with over 2000watts and 1. 15" and 2. 10" off this setup for 2 years worked great. I hit 152dbs on the spl at the last show I did. Mind you I was running a .5 farad cap but with what I was running well... Pheonix Gold loved me for a little while. Don't really matter to me though cause I'm into Horse Power now that I am older. Try what ever you want . Everyone has a opinion on these types of topics...the question is...who is right! Put it this way many girls Loved to ride in the back! If you know what I mean.
By the way nice Monte!
Old Dec 13, 2002 | 10:35 PM
87GTA Runner's Avatar
Car: 87 GTA
I just bought a Optima yellow top, I hope it's all it is supposed to be. I'm still probably going to have to upgrade my alt. I'll be running 3 amps with around 1200 watts total.
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
