installing 4th gen deck, need help
hi, i bought a head unit from a 98 firebird...it plugged right in to my old wire harness, and it works great. however, the mounting brackets/holes are different. i took my old brakets off from my old deck, but the 4th gen ones look like they are one piece with the whole radio casing.
anyone ever switched to a 4th gen deck have any helpful hints before i hack it up??
also, there is one extra spot for a wire harness (it came with the extra harness too)..if i remember correctly it had like 6 pins/wires? it is a Monsoon deck....could this be something special for that?
come on guys, i know someone out there must have used a fourth gen deck.
i need some replies BEFORE i get some free time to deal with this....because then the dremel comes out, and....
I'm doing the samething. Took 98 camaro deck and installed it. I had to use a dremel and file to modify the brackets as I didn't want to take apart the radio to try and modify. Also I had to modify the back of the radio pod for my car, as it made the radio stick out and wouldn't mount flush. The 4th gen radio is longer. Also I believe that extra plug is for the factory CD changer based on the reasearch I've done. Hope this helps.
Car: 00 TA, 91 Formula, 89 RS
Just out of curiosity, why did you get a fourth-gen deck as opposed to an aftermarket stereo?
thanks Grant...i got a dremel for Christmas too...woo hoo.
fyre...my deck went bad, so i needed a replacement. i didnt need some fancy features, and am not planning to build a system. for me, its more important for the lights to match the rest of the dash lights (hard to find a new aftermarket deck with oraqnge), and for it to fit and look factory (ive seen some nice 1 din mounts, but i prefer this) plus, when people get new aftermarket units, they sell them cheap enough to persuade me on ebay
Car: 1988 IROC
Engine: 5.7 HO TPI
Transmission: 4 spd Auto
There is an excellent article in the HOW TO section on another website, under the PROJECTS link, on how to put a 4th gen stereo in a 3rd gen car. One of them covers how to change the brackets out. Great articles, as I am doing the same.
http://www.iroczone.com/newindex.htm
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
