sub w/ Profie amp
Old Jan 14, 2003 | 09:55 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
Transmission: slipping 700r4, soon probuilt
sub w/ Profie amp
I want to get a 10" or 12" dual voice coil. For the time being I want to run it off my Profile Clarus 600 Cl which gives out 150x2 RMS. any ideas of what sub i should get for around $120? I was looking at Rockford, Alpine and Kicker but cant really decide.
Old Jan 19, 2003 | 05:27 PM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
why do you want a DVC?
you could try the Kicker Comps, RF HE2, or the MTX 6000's
Old Jan 20, 2003 | 11:31 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
What do you want out of your subs, SPL, sound quality, or a mixture of both? How much room do you have to play with? This sort of stuff matters.
I'd look into Elemental Designs or Adire as well as the other brands you mentioned. Unfortunately, these brands are more or less purchased directly, so you won't have a chance to audition them.
Old Jan 20, 2003 | 01:46 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
I would like sound quality over spl but good balance of both. thanx
Old Jan 21, 2003 | 09:46 AM
Jim85IROC's Avatar
Then I'd look into Adire, Resonant Engineering, Audiomobile, Elemental Designs, etc. All of them offer affordable drivers that should work very well. You can get 12" Shivas for $125 shipped, which might be one of the best deals in car audio.
Old Jan 21, 2003 | 11:17 AM
White Ninja's Avatar
First - running the right channel to one VC and left to the other is discouraged, i heard this could cause damage.
second - you might also want to look out, Running 1 sub, i take it you're going to bridge the amp. most amps won't run, and i know for a fact, the Profile won't run Bridged at less than 4 ohms, so....DVC might be tough. a SVC 4ohm would be your best bet. I'm not sure what the Shiva's are that were mentioned, but keep that in mind.
- Andy
Old Jan 21, 2003 | 02:36 PM
Jim85IROC's Avatar
A lot of DVC subs have dual 2-ohm coils, so you can just series-wire them and get a safe impedance.
Old Jan 21, 2003 | 02:58 PM
true
Old Jan 27, 2003 | 06:03 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
what are these shivas and were can i get them?
Old Jan 27, 2003 | 06:32 PM
mudaholic's Avatar
adireaudio.com .. i believe ampmanaudio.com sells them too
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
