Sub Boxes
Old Feb 19, 2003 | 02:18 PM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
Sub Boxes
How much would it cost to make a sub box for two 10's to go in the well of the rear hatch in my 86 TA? I want a little trunk space so i can put a bag or something on top. Any ideas as to how much it would cost? Thanks!
Old Feb 19, 2003 | 05:29 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
It all depends on what you have. I wil brake it down.
Saw: $45
Blade: $15
MDF: $25 per sheet
Screws: $5 per pound
Glue: $3 per tube
Carpet: $7
Spray Glue: $3
So this would cost you $128 with two sheets of MDF. Not too bad.
Brian
Old Feb 19, 2003 | 05:46 PM
ok thanks!
Old Feb 19, 2003 | 10:25 PM
xxwarrior36xx's Avatar
Thats what I have and I put the clamps in it to have the ttops bag still go back there. You needd to buy stronger grills than you get, they will break under the weight, just to warn you. I bought mine from a local audio place, carpeted for 200 bucks
Old Feb 20, 2003 | 04:33 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
Saw: $45
Blade: $15
MDF: $25 per sheet
Glue: $3 per tube
Carpet: $7
Spray Glue: $3
Brian
why would you need 2 sheets of mdf? you can pretty much make one with a 4x4 sheet
Old Feb 20, 2003 | 07:36 PM
White Ninja's Avatar
MDF is $25 bucks a sheet? If i remember correctly, when i went to home depot they were selling 2'x4'.75" sheets for like 6.50-7.00, did i read something wrong?
- Andy
Old Feb 20, 2003 | 07:55 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
4'x8'x3/4" i believe. thats about what it is here. probably closer to $20 though.
Old Feb 20, 2003 | 11:51 PM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
If your worried about settin a bag on top, build or have your box built like this...
[/img]
I can set bags in the back, if I had T-tops I could lay that over the box no problem. It will fit 2 12" but it is a tad small at aprox 1.67 cu. ft.
Old Feb 21, 2003 | 12:34 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I just bought a 4'x8' x 3/4" sheet at Menard's last week (to use for shelving) and it cost $17.88 without tax.
I have to say, it looks different though. Not as 'grainy' as it used to. It looks to be more solid. At first I thought they gave me the wrong stuff!! It looked like cardboard. They said they get it from a different mill now?
Old Feb 21, 2003 | 12:38 AM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Do you remember the first time you tried to make a box? And was it as complicated as a thirdgen well? I just think that if it is his first box, it will take two sheets.
Brian
Old Feb 21, 2003 | 02:10 PM
Well i actually decided to go with a custom box from the store i have been dealing with for my deck, they do really good work. The box is complete for two 10's and its carpeted (made out of MDF) for $145. So im just gonna go with them. I'll post pics when its done. Thanks for the replys though.
Old Feb 21, 2003 | 03:19 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
$145 for a MDF box from a shop is a really good price. All the shops I have seen have them for $200+
Brian
Old Feb 22, 2003 | 03:35 AM
biff85ta's Avatar
Car: 04 Vette
I only paid $160 for the box for my 12`s and its mdf with a protective coating not carpet so the box is more water resistant and if you have ever ruined your box because of a sudden hatch leak that wasn`t ther before you know that this is a good thing.
Old Feb 24, 2003 | 11:25 PM
YEah no kidding I got screwed!
Old Feb 25, 2003 | 08:15 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'd like to see what kind of box you're making from a 4x4 sheet. Any of my dual sub boxes use up almost a full 4x8' sheet.
And for anybody that's getting 4x8 sheets of MDF for $7... give me a call. You're my new supplier.
Old Feb 25, 2003 | 04:29 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
What kind of protective coating did you put on your box? My hatch just did that and I need to get it fixed but I want to have my box coated incase it happens again.
Old Feb 26, 2003 | 12:15 AM
biff85ta's Avatar
Car: 04 Vette
It came on the box but it kind of looks like rhino lining but it is much thinner and is harder the box was built by a company called pro box I believe.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
