Running a Fan
Old Feb 25, 2003 | 04:15 PM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
Running a Fan
Here's My Question
I want to run a fan on my amp.I want it to turn on when my head unit turn on as well as it turns off when my head unit turns off.How do i go about doing this and what kind of fan would i use.
Anth
Old Feb 25, 2003 | 04:42 PM
White Ninja's Avatar
it's simple, get a relay that's connected to your remote turn on lead. Whenever you turn the radio on it'll turn the relay on and complete the path to ground for your fan.
as for the fan, any 12v fan will do...the size depends on how much you wanna cool the amp.
- Andy
Old Feb 25, 2003 | 05:13 PM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
What kind of relay do i get i never done this before....
Old Feb 25, 2003 | 06:32 PM
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
why dont you just splice the power wire for the fan onto the wire that turns your amp on when you turn the headunit on?? and then ground it seems pretty legitimate to me.
Old Feb 25, 2003 | 09:09 PM
MdFormula350's Avatar
i would also put in a fuse..
Old Feb 25, 2003 | 09:55 PM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
Isnt it bad to splice a wire in to the head unit turn on.I thought you could ruin a radio if you do that.
Old Feb 25, 2003 | 11:21 PM
mudaholic's Avatar
depends on how much current your fan draws. its better to be safe and run a relay. and yes, you should fuse it too. check out the12volt.com for lots of good info on relays and other stuff too.. the kind of relay oyu're looking for is a SPST, commonly availalbe at any place that sells electronic stuff..
Old Feb 26, 2003 | 12:15 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Most remote wires can supports a few tenths of an amp current draws. Most small fans draw a bit more then a tenth. Definately use a relay.
Old Feb 26, 2003 | 09:27 AM
87z28TN's Avatar
Car: 1987 Camaro Z28
Definately Use a Relay
I would definately use a relay. Just find a relay that is compatible with a 12 volt system, and you will be fine. If you need any help wiring it up, just ask.
Old Feb 26, 2003 | 09:34 AM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
What amp relay what amp fuse?I want to use 1or 2 fans.
Old Feb 26, 2003 | 12:43 PM
def use a relay that turns on anywhere from 10-12v, and use a fuse to whatever the fans are rated at....if the 2 fans each run a 500mA rating, use somethig like a 1A fuse.
- Andy
Old Feb 26, 2003 | 04:21 PM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
THANKS
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
