Alpine CDA 7893
Old Feb 27, 2003 | 09:36 PM
91 Camaro Z28's Avatar
Alpine CDA 7893
i wanting to get that deck but i want some opinions on it before-- any help is appreciated
Old Feb 27, 2003 | 09:48 PM
chevkid's Avatar
Car: 87 SC
Transmission: t5
I have one and it's an awsome deck. Many features. I have it powering Infinity kappa 6x9s and factory fronts. it looks awsome at night and is easy to use. i love how the buttons are placed. by the way were are you buying from?
Old Feb 28, 2003 | 05:23 AM
indo audio on ebay is selling them brand new in the box from the factory for 259 so i'll get it from there
Old Feb 28, 2003 | 12:05 PM
Eric86TA's Avatar
I have that HU. I have a little bit of a glare problem on bright sunny days. Also, the angle adjustment is useless in my Trans Am. Other than that, it a very nice unit. It has good clarity. It has a lot of features that I will never use such as phase adjustments. I don't use the internal amp. I run three amps off of the RCA outputs. If you decide to use the internal amp you will need to run a seperate power wire to it from your battery. I can't remember off the top of my head but the fuse rating on the power supply was a little high for the stock wiring. I like the remote and the buttons on the unit but over all it is probably a little bit of overkill for me.
Old Mar 1, 2003 | 12:01 AM
92camaro44's Avatar
sweet....i just ordered one on ebay for 220..didnt know anyone here would have one...i did a lot of research...for the price and the features..it can't be beat..can't wait to install it
Old Mar 9, 2003 | 10:32 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
have it in my 89 formula it is a great un it with many features, and worth the extra time to install. not a unit you can go wrong with
Old Mar 10, 2003 | 05:24 PM
92camaro44's Avatar
sorry....i just got the 7897....alpine is awesome anyways
Old Mar 11, 2003 | 06:24 PM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
i got that headunit.....i love it.....had to do some cuttin to make it fit flush
Old Mar 11, 2003 | 08:04 PM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
Bubbakutz...what did you have to cut to make it fit flush? I am going to get one of those here pretty soon (exept it will be the MP3 compatable one) and I want it to be flush mounted.
Old Mar 11, 2003 | 09:15 PM
bubbakutz's Avatar
Engine: LG4
all i did was just cut the heat ducts out of the way and then covered up the holes with heat tape
Old Mar 11, 2003 | 09:37 PM
dyeinbreed's Avatar
i just got it, if youre still using your stock cassette player it will make a world of difference. I have it powering infinitys all around and it sounds real nice. The only thing i dont like is that the face gets real hot real soon, like hot to the touch when you hit the blue buttons. I don't know if this is the case with all cd players because this is my frist one. Everyones right, it does look wicked at night.
ps, mine was the display model at circuit city so they gave it to me for 239 which was a hell of a deal but they file off the eject button from the back so its pretty hard to get off but i will glue a piece to the back to make it work again.
This deck was 279 at circuit city, and they were all out of these since this is the last years model, so stop by and see if you can get some good deals.
Old Mar 12, 2003 | 03:53 PM
bubbakutz's Avatar
Engine: LG4
hot to the touch?! that does not sound very normal.....mine doesnt get remotely hot
Old Mar 12, 2003 | 07:26 PM
dyeinbreed's Avatar
its normal for alpines, it even says so in the booklet.
maybe you have the internal amp disabled. But if you crank it for a while it gets real hot.
Old Mar 12, 2003 | 07:54 PM
White Ninja's Avatar
i took a heat gun and heated the plastic up really good, then used a rod to push them in uniformally. i didn't wanna cut anything and have the heat going into the cd player chamber....might be ok when the AC is on though....
- Andy
Old Mar 13, 2003 | 06:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
An alternative Alpine pehaps.
JamesC
Old Mar 13, 2003 | 06:47 AM
JamesC's Avatar
Oops!
JamesC
PurelyPMD
May 5, 2016 04:57 PM
sreZ28
Oct 22, 2015 08:21 AM
the_hamturdler
Sep 30, 2015 12:50 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
rudolphschenker
Sep 4, 2015 02:41 AM
