dvc
Old Mar 3, 2003 | 11:09 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
dvc
I have a 1988 camaro with four twelve inch woofers kicker comp vr dvc with a 500 watt lanzar amp.the problem is when all voicecoils are hooked up and you turn it up speakers sound like two 10 inch speakers, but when i hook one side of the voicecoil the speakers pound head could the be bad hooking one side of the coil up.
Old Mar 4, 2003 | 12:52 AM
mudaholic's Avatar
how do you have them wired? the impedance could be too high the way you are wiring it.. also, you might think about upgrading your amp if you're gonna be running 4 subs
Old Mar 4, 2003 | 01:23 AM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
my money would be one that you wired some out of phase, reversed the + and - . doing this makes the subs cancel each other out. make sure that the wiring is correct.
if that doesnt change anything try wiring up each sub one by one and see if any dont work correct.
my money still goes on 1 or 2 being out of phase. good luck.
Old Mar 4, 2003 | 07:41 AM
9177's Avatar
I Agree with mud you need more power. Those comp vr's can handle plenty unless you have them in a very big box. I have heard its bad to hook up one coil but im not positive.
Old Mar 4, 2003 | 09:23 AM
antoine's Avatar
also they are duel two ohms speakers, and what amp should i be running them with.
Old Mar 4, 2003 | 10:31 AM
White Ninja's Avatar
Re: dvc
when you're only hooking up one voice coil it's only 2 ohms, when both are hooked up i think they're in series, so it's 4 ohms...
- Andy
Old Mar 4, 2003 | 03:42 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You can do it one of two ways to get 4 ohms back to the amp.
This one's kinda hard to understand. The other one's MUCH WORSE!!
Old Mar 4, 2003 | 03:43 PM
AJ_92RS's Avatar
This one's harder to understand just because the artist sucks.
Just follow along with the math and you'll get it.
cbarry
Car Audio
Jun 25, 2002 11:02 PM
EjBaL
Car Audio
Jun 20, 2002 11:07 PM
CD MaroMan 91
Car Audio
May 7, 2002 09:58 PM
PimpRod92RS
Car Audio
May 1, 2002 09:17 AM
DABE
Car Audio
Apr 15, 2002 10:48 PM
