Something other than 6 X 9s in the sail panel
Old Mar 6, 2003 | 12:23 PM
87z28TN's Avatar
Car: 1987 Camaro Z28
I know that this has been asked some before. I also know that the factory toyed with this idea. Would there be any sound advantage of changing from 6 X 9s in the sail panels to perhaps a 6 3/4 inch speaker? Would it be possible to put more than one speaker back in the sail panel. Maybe like a 6.5 and a 3.5? Any input you guys I have will be greatly appreciated.
Thank in advance...
Old Mar 6, 2003 | 04:54 PM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
sure its possible, but why? i have a pair of 6.5's back there but that is because i am a SQ guy and i just needed a little rear fill.
all you have to do it make a template out of wood and cut the the size speaker holes that you want.
good luck.
Old Mar 6, 2003 | 04:59 PM
joshua chandler's Avatar
some ta's came with 4x6 and 3.5 in the rear i just removed mine
Old Mar 9, 2003 | 03:17 PM
84s/e's Avatar
Car: 1984 Firebird S/E
Engine: 5.0 lg4
I have a 6.5 in component set with the tweeters in mine.
Old Mar 9, 2003 | 07:33 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
i have 6.5" coax in my sails. no benefit to putting in multiple sets in there. 3.5" speakers arent really good for anything anyway (trust me, i drove a taurus for a while. 3.5"=crap )
Old Mar 9, 2003 | 08:02 PM
A88GTANotchback's Avatar
Thats what i wanna do. seems like the bvest set up to me at least
Old Mar 9, 2003 | 08:19 PM
patrickm00's Avatar
you can put whatever you want back there, even an 8" woofer/sub will fit (won't sound great, but would fit).
just remove the steel panels that hold the 6x9s (4 screws, but you might have to take the plastic interior part off to get to them), then get a similar piece of sheet stock steel or aluminum from home depot or lowe's, drill holes, cut a speaker hole, and put it in. a dremel with one of the metal cutting tips (either the discs or the 1/16" thick one that looks like a tiny circular saw) works well.
Old Mar 11, 2003 | 03:56 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I put 5-1/4's and tweeters in my sail panels and I found a great material to use instead of wood-- masonite. you can get sheets (or half-sheets) of the stuff at Home Depot and it's cheap, sturdy, easy to cut, and is thin enough that it can screw right into the location of the 6x9 and the cloth speaker cover will still fit over it.
Old Mar 14, 2003 | 11:37 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
must refrane from cutting up counter top in kitchen. no seriously, i am suprised it took people this long to use it because you can get it in al sorts of different patterns and thickness and strength. it is almost as good as mdf in my opinion, and if the masonite was had a layer of fiberglass over it, then the sound should surpass the mdf. jmo.
thanks
anthony
Old Dec 6, 2004 | 01:14 PM
85and87's Avatar
Car: 85 and 87 trans am
Engine: 305 to be 383
i had an 8'' and a 4'' when i took my speakers out. it was out of a junk car this guy half superglued the interior together and everything was out of wack.
Old Dec 6, 2004 | 10:31 PM
onebadwagon's Avatar
the ONLY thing i would think of putting back there would be a set of sub/midbass drivers.
i'd do a couple of 8" subs in the panels, but it's going to be a pain in the *** to get any kind of 'glass work done in that area.
Old Dec 6, 2004 | 10:34 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
I have 4x4's in there with tweeters, sounds awesome!
Old Dec 8, 2004 | 10:56 PM
85and87's Avatar
what kind of glasswork would you need any why
Old Dec 9, 2004 | 02:21 AM
if you wanted to use 8" subs as sub bass, you would need to put some form of an enclosure inside the sail panel. if you can think of a better way than fiberglass, you're one step ahead.
Old Dec 9, 2004 | 10:31 PM
85and87's Avatar
the way the guy has mine was done with a piece of wood bolted to the frame and fiberglass around it. thats taken out now though and 6x9's are in it.
Old Dec 10, 2004 | 10:12 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
there was a thread about 8in subs in those sail in custom glassed panels that faced the sub foward towards the front of the car... its was awsome looking but ive lost track of it during time.. search and you should find it
Old Dec 10, 2004 | 06:18 PM
Gambit69's Avatar
Car: 1989 Pontiac Firebird Formula 350
I think you were talking about these custom sail panels
Old Dec 10, 2004 | 09:49 PM
i'm sorry, but that is ****ing disgusting.
Old Dec 11, 2004 | 07:36 AM
Gambit69's Avatar
They are not finished yet. They still need to be sanded smooth and will be painted gloss black
Old Dec 11, 2004 | 10:21 AM
i'm not talking about the finish, i'm talking about the design, and speaker placement.
Old Dec 12, 2004 | 06:54 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
IMO thats alotta work thats been going into them and i think if they sound as good as i think they will its pretty awsome
Old Dec 12, 2004 | 07:02 PM
Gambit69's Avatar
I still have to finish the outside of it as well as put in a divider inside it to keep the 6.5 and the 8 in different chambers so they won't hurt each other.
Old Dec 12, 2004 | 11:03 PM
i sure hope you have a nice pair of front components, if you wasted a pair on the back of your head.
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
FormulaEngland
Sep 30, 2015 01:50 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
formula00ra
Sep 28, 2015 11:50 AM
