Amp and speaker compatability
Old Mar 17, 2003 | 04:59 PM
KsKid's Avatar
before i buy the JBL 600.1 amp from Ikesound i want to make sure that this will work. i have 2 Rockford Fosgate 10 inch punches. they are 8 ohms a piece. RMS is 150 Peak is 400.
the amp is rated at
Output 4 Ohms: 300W x 1
Output 2 Ohms: 600W x 1
if i wired my subs in parallel that would give me 600W right?
thanks alot for any help, this is kind of complicated to me so any help is appriciated.
Old Mar 17, 2003 | 05:14 PM
KsKid's Avatar
ohya, i dont want to run it at 4 ohms, at 2... if its possible how would i wire 2 8 ohm subs to get them down to 2 ohms?
Old Mar 17, 2003 | 11:47 PM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
you cant...sorry
Old Mar 18, 2003 | 08:38 PM
ROC-Z's Avatar
If your going to run the impedence down to 2 ohms, make sure you have good cooling on your amp.
If you wire your (2) 8 ohm loads in parallel, total resistence will only be 4 ohms.
You need to have a total of (4) 8 Ohm speakers in parallel, for a 2 Ohm load.
Old Mar 18, 2003 | 08:51 PM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
Look at it this way...you want 2 ohms...that gives you an excuse to go buy 2 more subs! ...hey, you goin to the Disturbed/chevelle/Taproot concert at the colesium? Its gonna be AWESOME! so is the 50 Cent/busta/clipse conecert a week and a day before Disturbed...im goin to both..CANT WAIT!
Old Mar 18, 2003 | 09:56 PM
KsKid's Avatar
ummmmmm no! thers to much other stuff that i could use the money for. like an amp...
Old Mar 19, 2003 | 06:14 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
Hahaha, ya, I guess your right, its still gonna be awesome. I can wait a lil bit longer for an amp so I can go to the concerts. I should be getting half the money ($400) tomorrow (Thursday) so I can get the JBL 1200.1 and the second sub, and then when I get the other half I will get an alpine CD Player and a JBL 80.4
Old Mar 20, 2003 | 05:44 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
Call me crazy, but your subs are rated for 150 watts rms, and at 4 ohms the 600.1 will put out 300 watts. So if you ran the two speakers in parallel, that would put you at 4 ohms, and give you 300 watts, which is just what you need. So why do you want to run at 2 ohms?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
wanext
Oct 6, 2015 12:18 AM
raymondandretti
Sep 27, 2015 06:43 PM
