My sound system
1 Post
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
i have 3 pics of my amp...i know it wont power my sub but could it power my 6x9s?
1 Post
top of my sub, not the actual box ill be using, ill be making a good one once i can get it in the trunk and not interfeer(sp?) with the t-tops
1 Post
bottom of sub...the box is like 2.5 feet square and made out of diferent width plywood...it was like that when i bought it
1 Post
heres the 6x9s in boxes but ill be taking them outa the boxes and puting them in the sail panels once i get the car on the road
Car: See pic above
Engine: Too Small
Transmission: Broken
Re: My sound system
Originally posted by 83Firebird420
my deck...
my deck...
1 Post
Re: Re: My sound system
Originally posted by joezero
Which one is it? I vote for the honda one!
1 Post
Car: 00 TA, 91 Formula, 89 RS
Car: See pic above
Engine: Too Small
not unless you use it to power your subs. It's a mono amp so it wouldn't produce seperate left and right channels needed for the 6 x 9s.
Car: 1989 White Trans-AM
Engine: 305 TPI hopefully Upgraded Soon.
Transmission: Crappy Needs Improvment.
nice looking but lets see it all installed i wanna see this...
1 Post
1 Post
thanks mdformula350
im bored so i thought i might was well tell u what i paid for it all, the deck and the 2 front speakers were 60$ (front spaekers are pyramid's and are 4" diameter), the sub came with the cheap amp and box for 160$ and the 2 6x9's with the boxes was 100$, so it was a fairly cheap and good system.
Car: 1989 RS Camaro
You shouldn't have to use a amp to power your 6x9s anyways, unless u have a really ****ty deck. If you've got aftermarket speakers in front and back it should sound fine. Only use the amp if ur going to hook up some subs. Put the 6x9s in the sail panels, right now they look like wannabe subs. Also u should make a new box for your sub, the box sucks if its made of plywood, use something good like MDF.
1 Post
1 Post
cuz the guy who owned it b4 me had a crack head build a box for it.
Car: See pic above
Engine: Too Small
MDF is the material of choice for most people. You can also use birch, altho that is quite a bit more expensive than MDF. If you're trying to do things as cheaply as humanly possible, some people have had moderate success with 3/4" particle board. What's nice about MDF is that it is really smooth and bonds well with body filler. So it's the best route if you're planning on doing any fiberglass work or if you want to get the surface of your enclosure super smooth. I like it for that reason in particular because I tend to use thinner fabrics as opposed to the standard box carpet.
Car: See pic above
Engine: Too Small
Originally posted by MaineIrocer
How hard is it to create a box if you have never done it before?? And where can i get directions to build one?
Car: See pic above
Engine: Too Small
JoeZero that is a sweet box how much did that cost you to build? Where you from?
I'm from California, I live just south of Sacramento, the greatest city in the world.
Car: See pic above
Engine: Too Small
Recessing an amp isn't difficult at all so long as you have the right tools. Basically you trace the outline of the amp on the whatever surface you want to mount it to. Then drill a pilot hole and cut it out. Then you attach another peice of MDF (about 1" bigger than the amp on each side) to the back. You don't need to screw it, just use a lot of glue. Then caulk around it from the inside just like you did for the rest of the enclosure. If you want it deeper than 3/4" then just glue on another piece of MDF and then cut it out just like the top. You can keep doing this to make spacers. When I do multiple layers, I like to sand it all nice smooth before I put the back on. Hopefully this pic will help a little.
Car: 1986 Iroc-Z
Transmission: Automatic
Thanks that does help.... I am not planning on building a box until sometime in June once the rest of my car is all set and ready to go....so you might here more from me down the road...
Car: See pic above
Engine: Too Small
Do the 6x9s that you built into you box? Do they do anything extra or are the just for looks??
But I really do like the way it looks. It lights up at night and you can see it through the back window. If you have any questions down the line, don't hesitate to email me (cause I never remember to check my PMs on here). Good luck!
1 Post
Originally posted by jesse23
that setup looks SUPER ghetto to me lol
sorry but its true
sorry but its true
so is the rest of my car haha
Car: See pic above
Engine: Too Small
I completely forgot that I had put together a website about building the enclosure. It's got a lot of construction pics on there, hope they help. www.geocities.com/jcargile2001/stereo.html
92projectcamaro
01-18-2016 08:00 AM
