two radios possible?
Old Apr 20, 2003 | 07:16 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
alright i was wondering if i can hook up and aftermarket cd player to my stock am/fm/cassette? can i just splice the speaker wires and go? i would turn off the cass player to use the cd and subs and then turn that off to use the am/fm tuner. i dont want to hack up my new car so can i just splice the speaker wires to work on both?
Old Apr 20, 2003 | 07:26 PM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
i don't know what the hell you're trying to do by that
screw the two radio idea what you need is a GM quickconnect radio adapter to go from the factory harness to the new cd player and an install kit for the cd player to go in the factory location then add your amp and subs and on the blue remote turn on wire that runs from the cd player to the amplifier for the subs you want to run a switch to turn the subs on and off so you can choose between just the factory speakers and a full system if you want a pic with a better eplanation let me know
Old Apr 20, 2003 | 08:33 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
nevermind. i guess i am out of my gord. no one understands.
Old Apr 20, 2003 | 09:01 PM
Drunken_Polak's Avatar
ROFL BADANDY ur sig is HALARIOUS!!!!
lol...circle the problem....hahahahaha
Old Apr 20, 2003 | 11:18 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Putting a cd player isn't by any means hacking up the car.
Old Apr 21, 2003 | 09:25 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
i dont want to hack up the oem faceplate. its a 2000 ford taurus and a rectangle in that big oval faceplate looks really horible. i just wanted to mount mine under the dash since i have a remote anyway.
Old Apr 21, 2003 | 10:46 AM
jawzforlife1's Avatar
check this out, it is a cd player with no radio, it plugs into your antenna, volume is controlled by factory unit. All you have to do is find a place to mount it. No wires to splice.
http://www.crutchfield.com/cgi-bin/S...=0&cc=01&avf=N
Old Apr 21, 2003 | 12:13 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
go to www.crutchfield.com and put in the info for your car. i dont know if they charge extra for that car, but they make an adapter that replaces the oval piece. doesnt look too bad.
Old Apr 21, 2003 | 12:17 PM
might be able to use this to put the sony player under your dash
http://www.crutchfield.com/cgi-bin/S...=1&cc=01&avf=Y
Old Apr 21, 2003 | 01:02 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Jaws, that's the same thing I was thinking of. If he doesn't want to dive behind the dash either, I've seen a unit named "soundfeeder", and it works by proximity... your radio picks up the frequency of this soundfeeder, and you hear the CD player thru the radio. Only problem is that since it's not directly linked thru the antenna wire, you might get some static.
There was some kind of court ruling that said aftermarket radios don't void new car warranties as long as they're installed properly and don't destroy the car (if it's a lease)... just like adding an aftermarket exhaust or new wheels.
Old Apr 21, 2003 | 02:44 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
thanks guys, i found a shop that is going to put it in under the dash out of the way and keep power to the stock radio for the clock. i did it that way just to keep the stock faceplate and put it to use.
Old Apr 21, 2003 | 02:48 PM
So they are just hooking up a aftermarket cd player to the original head unit.
Old Apr 21, 2003 | 08:19 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
they are disconnecting the stock radio and putting the harness on the new cd player and i am having them run a hot wire and a memory wire to the old radio to keep the clock working. that way the old one isnt just sitting there doing nothing.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
Fireslash
Apr 11, 2016 06:43 PM
Gunner242
Dec 25, 2015 04:49 PM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
