Power Antenna not fully extending
Old May 9, 2003 | 11:51 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Hey on the 90 Formula with a stock sound system, the power antenna only goes about halfway up, and stays there until you turn it the radio off. I still get good reception, and you don't notice anything besides how tall the antenna is. Is this anything to worry about?
Old May 10, 2003 | 08:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Reminds me of a situation I had some time ago: My ant didn't go up all the way either (but mine was only lacking a couple of inches), and like yours the reception was fine. Long story short, in fiddling with it, I managed to break it altogether. The GM replacement was around $100, if I recall correctly. You might consider leaving well enough alone.
JamesC
Old May 10, 2003 | 09:17 AM
Drunken_Polak's Avatar
Im Not sure how usefull this article is....or how well it applies to third gens...but u might wana give it a look over!
http://popularmechanics.com/automoti...ech_july_2001/
Old May 10, 2003 | 10:40 AM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
Damn and I just broke it off the other day and removed it because It snaped when I was trying to bend it back so It would go down all the way Oh and can I just cut the wires from the power antenna or what?
Old May 17, 2003 | 11:37 PM
1989TransAm's Avatar
well...i have an 89 trans am, and when my antenna motor went bad, was constantly on, and the antenna was always up i had to disconnect so it wouldn't drain my battery...what i did was i went under the passenger side kick panel in the front, and just clipped the wire...i can't remember off hand what color it was, but that stopped the motor from running, it's a bi*ch to get to that antenna wiring any other way.
Old May 18, 2003 | 06:14 AM
JamesC's Avatar
Couldn't you simply disconnect the relay to the antenna instead of clipping the wire?
JamesC
Old May 19, 2003 | 12:57 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The GM power antennas were famous for that; the "fishing line" nylon cable snaps, and the motor just spins.... sort of like how the pull-down hatch motor breaks!
Yeah, he could've disconnected the 3-pin connector at the relay.
My power antenna was dead when I got my car. Snapped it in half when I drove "off road" in a park, underneath a low-hanging tree branch. Heh... I thought I was cool going under the low branch, because, you know, my car would fit underneath. I totally forgot about the antenna.
Anyway, I threw the pieces out and put up a regular 'ol mast antenna. I've never been happier! I cut the wires off under the fender. My power antenna relay now turns on my car amps (patched it into the 3-wire connector, off the relay- the same connector that the antenna came off of.)
Old May 20, 2003 | 10:46 PM
92Transam's Avatar
JamesC
I couldn't find it so I pulled the antenna apart hopeing it would have a connector in it and found non so I sniped them and taped them off
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
db057
Sep 4, 2015 07:57 AM
sailtexas186548
Aug 24, 2015 10:11 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
