sealing rear 6x9's
Car: 83 Camaro
Transmission: th350
sealing rear 6x9's
ok i installed my new 6x9's in the sailpanels but the screws dont want to go in tight.....what should i do....1/2" mdf panel instead of metal maybe?
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
how about this idea kinda on the wild side but hey it may work. go up one size on the screw, maybe a sheet metal screw, self tapper may be the way also, forget the wood.
Car: 89 GTA
Engine: 350 LT1
i took a piece of 1/4 mdf (i had 1/4 and 3/4) and traced the metal plate (rectangle) and marked the 6x9 opening.. I used that.. and it is real good. I put 5.25" coaxial JL's not 6x9's but you can bolt up the 6x9 just fine.
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
well i have 2 infinity kappas in my sail panels and they were rattling like crazy. so i made up a wood plate and siliconed it to the car
. much better sound, but now other things are vibrating...i need some sound dampening
. much better sound, but now other things are vibrating...i need some sound dampening Thread
Dialed_In
Aug 20, 2015 01:45 PM
