help i got static
Old Jun 17, 2003 | 10:48 PM
750gixxer's Avatar
help i got static
i just put in a aftermarket cd player now when i listen to radio fm or am i get i little static but only when car is runing turn the car of it sounds great is this a prob with ing.wires?if so what do i do i dont know much about car radios
Old Jun 19, 2003 | 09:56 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
It's possible that you have a ground loop. Does the noise increse when you give it gas? It usually happens with amps but can happen with CD players as well. Check the ground and/or give it a new ground.
Later,
Matt
Old Jun 20, 2003 | 12:33 AM
750gixxer's Avatar
no it dosent i have herd what i bad ground sounds like and this isnt it. it dosnt have static on every fm chanel but the ones it does u can turn the key back to where the car turns off but the radio is still on and the static goes away
Old Jun 20, 2003 | 01:41 AM
onebadwagon's Avatar
get some better plug wires, to start with, see if that changes anything,
RF interference, if it only happens on certain stations can cause that problem.
adam
Old Jun 20, 2003 | 12:32 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
check your ant wire. make sure you have a real good connection.. and wrap the connection in elec. tape. I had to get an adapter for my stereo.. all it was is a chunk of wire with a straight end on it instead of the 90 that is on the car.. That way I got a real solid connection.. and it cost me llike $3.. they stock them at the stereo shops.. However that may not be your problem..
db057
Jan 10, 2020 08:55 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
Andrew6.688
Dec 13, 2015 10:59 AM
80 Camaro 355
Car Audio
Dec 31, 2002 08:18 PM
