Power Antenna
Old Jun 27, 2003 | 09:32 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Power Antenna
Well, I just got home and shut the eng. off and the power antenna moter kept running. I was to tired to check it out so I just disconnected the batt. Went to the Archives and read what they had to say but are there any other suggestions. Can the P/A be removed and repaired? Can you buy a rebuilt? Is there a manuel antenna avaiable ect. ect?
Auggie
Old Jun 28, 2003 | 12:53 AM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
gm has a rebuild kit. there is a relay under the dash on the passenger side. to find it, when you turn to the radio on or off it will click. then you will know where it is, to get it to stop running all the time, just unhook one of the leads going to it. the rebuild kit is somewhere in the neighborhood of 20-30 bucks.
Old Jun 28, 2003 | 08:53 AM
Auggie's Avatar
Tamu130, thats good news. Do you happen to have any part #'s for the rebuild kit. Oh, and how do you get that thing out of the fender. Thanks a bunch .
Auggie
Old Jun 28, 2003 | 11:03 AM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/sho...ntenna+rebuild
Old Jun 28, 2003 | 03:24 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
yeah just read one of those posts. it seems pretty easy but alittle time consuming. im gonna have to do it soner or later myself.
Old Jun 29, 2003 | 10:59 AM
Auggie's Avatar
Thanks to every one for all the info. You guys are great :hail: .
Auggie
Old Sep 13, 2003 | 10:16 PM
Poesmom's Avatar
Power Antenna
Hi.. I'm new here. I trust girls are allowed? I didn't intend on joining but since I found help in your forums it seemed only right that I should say thank you for the info. My p/a in my '89 RS still works. It doesn't continue to run, which appears to be the most common problem. Mine only goes half way up. (Not the best reception for weak channels) It retracts as it should. I was going to replace it with a manual one but since it is such a pain to get the cable in and out from under the dash I figured it's worth repairing if possible. I found the cable part still available at www.gmpartsdirect.com providing that is what I need. Now, if I can only get my boyfriend to take it apart .....yeah, he will.
Thanks again.,
Nancy
Old Sep 15, 2003 | 09:42 PM
Poesmom's Avatar
Power Antenna
I remember reading in prior posts where the GM parts book said there was no rebuild kit for late 80s models and I now understand why. It appears we got disposable Power Antennas because the case is rivetted shut. You can't get into it to replace the cable and/or the mast. So, I guess I will just run it half way up until it quits altogether. We tried putting a manual one in that I bought at Fry's and the cable wasn't long enough. Geez!
Nancy
Old Sep 16, 2003 | 01:24 AM
Timbo89GTA's Avatar
Car: 89 Trans Am GTA
Engine: 383 TPI
Axle/Gears: 3:27
This is all you will need I just did it pretty easy. good luck
22020281 is the bolt kit for the rebuild..
22038195 is the rebuild kit......Cable etc
20664092 - Inner Fender Retainers
Old Sep 18, 2003 | 12:04 AM
Poesmom's Avatar
Bolt kit? Meaning to pop the rivets lose and there is a bolt kit available for putting it back together? Alright! :lala: Thanks alot! We already put it back in the car and I'm using it at half m'assed, so ta speak. But I will write these numbers down for future reference.
Nancy
Old Sep 18, 2003 | 03:28 PM
Auggie's Avatar
Well, so will I:hail:
Auggie
My car with the antenna down.
Old Sep 19, 2003 | 07:08 PM
Poesmom's Avatar
A/C
Hahaha Any excuse to get a picture of your car in here, eh?? It's beautiful! Mine is similar. Black, but no red. I'll post a picture of it as soon as I wash it. Now, if it's permissable, I have a question on a different topic. What do you do when your air conditioning runs out of freon? I understand the "old style" freon is no longer commercially available, but is it really necessary to convert to the new style? Or are there still folks out there who can service mine? BTW, I'm in the SF Bay Area in California.
Nancy
Old Sep 19, 2003 | 09:58 PM
Auggie's Avatar
Well, you are right. I have been, as you can see on this board for awaile and just learned how to post pics. Its funny you should ask about the A/C Nancy because my compressor just hatched this summer. I bought all the parts and had a shop install them and charge the system with 134a. Total cost was $315.54. I wish I would of done the conversion before the comp. hatched because it would have been $125 less. Driving down the freeway at 70 mph on a 85* day I get 40* out of the center vent.
Auggie
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
