Sub Box
Old Jun 30, 2003 | 10:37 PM
kylem's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.7 Tuned Port Injection
Transmission: 700-R4
Sub Box
hey guys i have a 1989 Iroc-z, and i plan to put 2 Infinity Reference 10's in it..... I need to know what i should build my box out of and what designs i should use b/c i have to mount my 600W Jensen Amp somwhere.. I also would like to know if there are any specialties or tricks i could use to get a good sounding bass. Well guys hope you can help me...
Thanks,
Kyle
Old Jul 1, 2003 | 01:27 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
The way I built my box I can fit my 12 disc changer and the amp underneth in the pit where the t-tops go(I don't have them, so don't need the space). My box sits right on top across the little ledges to either side.
To get good sounding bass, get the box as close to the sealed space specs that the speakers come with. My box is about 2.5 cubic feet inside and my speakers are speced at needing ~1.25 of sealed space each. The inside is totally hollow, so the 2 subs share the same air space, but since they are briged, they both pull on it at the same time so it works out. I tried mounting the subs so they fired straight up once, but since I angled them forward, I think the bass is a lot cleaner.
You can check out the box on the second page of my cardomain site. I plan to carpet the bottom and sides of it and put vinyl on the top with the chevy bowtie in-between the speakers.
Old Jul 1, 2003 | 01:36 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
dude..... get a photo editing program and black out your plate on your car domain site!!! not only do thieves know whats in your car, they can identify it 100%. kindof a low risk, but cmon....
Old Jul 1, 2003 | 01:38 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
not that worried about it. I agree with what someone said about that, "They can see your plate when you drive down the street anyway, so what's it matter?" I figure that with the way I play my stereo, they're gonna know that I put some work into it anyway, so screw it.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
