opinions needed on subs...
Old Jul 27, 2003 | 01:13 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
someone was telling me about free air subs & i was wondering if it hits hard or sound like cr@p???
Old Jul 27, 2003 | 01:29 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
Free air subs aren't going to sound as good or be as loud a subs in an enclosure. The up side is that all you need is a baffle board instead of a whole box, so you could have your system up and running in an hour.
Old Jul 28, 2003 | 03:54 PM
Engine: 283
k,thanks!..........no one else has opinions on this topic??????
Old Jul 28, 2003 | 10:04 PM
paul russell's Avatar
Car: 86 trans am
Engine: 5.0 tpi gtauto ramair and notch
Transmission: 700 r4
i have used both and i found the free airs i have just installed rock. A few have heard them and was suprised, even fooled a few ppl. and had to show them it was not a box. I personaly do not think you will be disapointed
Old Jul 28, 2003 | 10:06 PM
SuPeR SpOrT's Avatar
whats a good free air sub to get?
Old Jul 28, 2003 | 11:50 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
With "good" being a relative term, Pioneer.
Old Jul 29, 2003 | 01:10 AM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
I think the term free-air is a little misleading to some people. Free-air subs are supposed to be really hard to get to sound good but I do not have any really experience with them. The idea is that say you have a car with a trunk. A free-air sub, properly installed, will still have an enclosure, the trunk. The baffle board has to be air-tight or air will leak out and the sub will not sound good. The trunk is supposed to be seal, so in effect you will still have an enclosure, just a really big one, which means the sub will not be using the air inside of the box to assist in the suspension.
If you decide to just through a board over the back well and drop some subs in, they will not sound good, and I have tried this on my very first system, it sound terrible. If you a simple good sounding system I would recommend a sealed box.
Good luck either way.
Old Jul 29, 2003 | 01:47 AM
91305z's Avatar
A big plus is that you can use a baffle board (10 lbs) or something to that extent as oppossed to a sealed or bandpass box that weighs a ton.
Old Jul 29, 2003 | 01:49 AM
joezero's Avatar
Car: See pic above
Engine: Too Small
If you build the baffle board correctly, they can sound good. But, remember that a box gives your setup a lot more integrity than just a board. My brother used to just have a free air setup in his 89. But after about 6 months, the weight of the subs cause the baffle board to begin to bow. The more it bowed, the more air leaked, the quieter it got. You will never be able to fully seal a free air setup, so you won't ever get the efficiency out of the subs that an enclosure will get you.
Old Jul 29, 2003 | 06:08 AM
9177's Avatar
Actully the correct term you are looking for is infinite baffle which can sound very good with certain speakers but mostlikley not in a camaro. There are some people that run IB for sound quality using speakers like the ID MAX, but like I said not in a camaro.
Old Jul 29, 2003 | 08:29 AM
Car: 86 trans am
3/4 mdf will hold the weight welll no sagging issues, however with parlicle board you will get sagging pretty fast.
Pioneer"s imp series are very nice sounding freeair's
Old Jul 29, 2003 | 06:14 PM
Engine: 283
pioneer isnt too shabby....i had a cd player by them & it lasted for like 4 yrs...then it started skipping & i sold it for like $20 ...lol
"sagging" lmao----caught me as funny :lala:
Old Jul 30, 2003 | 12:16 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
I made my own sealed box and it is awsome.
I really like the 2 JBL 12's i got from crutchfield for only $150 for both. Hits soo hard shakes my tail lights out of place all the time.
here is a drawing of the box, i know horrible work but gets the idea across
Here is my current set up with the JBL's
Old Aug 1, 2003 | 04:49 PM
Engine: 283
thanks guys for your help & opinions! :lala:
Old Aug 8, 2003 | 09:29 PM
Anjiru's Avatar
Uhm tight set up but........ how do you feel about having those puppies in bright daylight like that?? I would feel very scared some1 would want to try to steal them..... do you plan on at least tinting the car
Old Aug 9, 2003 | 12:21 PM
Car: 87 Firebird
Engine: 5.3 76mm
Well if you check my sig now... i dotn really talk about it but i got like 5% tent on there. So only like 1% uv light hits them and liek only 25% radiant heat hits them, so they stay rather cool. LOL
Only thing though is the amp does get warm to the touch out in the full sun with the hatch sut, just that thermal dymanics thing again
Old Aug 9, 2003 | 09:22 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
The rear deck lid will cover most of it too, so it's a bit less visible. But I say, if you've got it, flaunt it
www.geocities.com/jcargile2001/stereo.html
Old Aug 11, 2003 | 10:21 AM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Another point I thought should be made is to make sure you use "free-air" speakers if you're going to use a baffle-board. I had an old factory MTX baffle board and it sounded o.k. I only had 75W/ch on the subs and I still eventually blew them. I replaced them with whatever Lanzar's best speaker was at the time. Yeah, those lasted about a week since they were designed for a sealed box. I then built a box and I only blew dash and sail panel speakers after that...
Old Aug 13, 2003 | 10:38 PM
Engine: 283
exactly!! lol
thanks guys for ur help & opinions...all of ur info was very useful
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
