speaker box design....
Old Aug 1, 2003 | 10:49 AM
KYL98's Avatar
Car: 1991 Z28
I was curious to see some 12 in box designs....I had a box with 4 8in solo-barics(old style) but somebody decided they liked it more than I did and took it Anyway, I wanted to see some pictures of some boxes with 12's in it. Ill be making mine out of pine(ALOT lighter than particle board.....) Now before you say anything bad about pine for boxes, think about how much lighter it is. My last box had NO leaks and I hit 129db's in my only contest to enter. It was completely airtight, and about 10-20lbs lighter. so...send the pics please....thanks guys.
Old Aug 1, 2003 | 08:55 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Here is my current set up... well the drawing anyways...
And here is it all installed...
They are the GT120 serries subs, 12" JBL. Good price but i dont think the box will be big enough for serious sound. But for what im using them for they sound awsome.
And hit just as hard if not harder as they should for $150 a pair
Old Aug 2, 2003 | 07:54 AM
NOCANDO's Avatar
Here's mine...three 12's in its separate enclosure.
Old Aug 2, 2003 | 08:57 AM
onebadwagon's Avatar
nice setups, i love the old pheonix gold stuff.
adam
Old Aug 2, 2003 | 07:14 PM
NOCANDO's Avatar
Thanks onebad....Its two amps...M44 and M50. M44 runs my mids and highs...the M50 is bridged in 2 ohm mono to run all three 12" kickers freeair. So far I've placed first place two years in a row for SQ until they stopped the category. Most people are into DB drag.
Here's a shot of my amp rack at night with neon
Old Aug 2, 2003 | 07:16 PM
NOCANDO's Avatar
Treasures of hard work......can I go home now.....:lala:
Old Aug 2, 2003 | 11:49 PM
magnethead794's Avatar
Re: speaker box design....
Originally posted by KYL98
ALOT light than msd
oh, yer saying pine is lighter than msd......which is an ignition system company. don't compare wood to electrical. LOL! i suggest an edit.
Old Aug 3, 2003 | 12:52 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Hye Mitchell, what wattage amp are you using there, and how powerul are those subs? I know that you have a Jensen amp, becuase I have a 340W version of that amp. Just curious, I guess. I have a single Sony Xplod 12" 1200W and am looking to build an enclosure for it and its mate when I get it.
Old Aug 3, 2003 | 01:02 AM
warning
If you have a jensen..be VERY careful, especially with the LXA's...we just blew an LXA600 a week ago, and a LXA300 2 yrs ago....they have few protection circuits......we should know.
Old Aug 3, 2003 | 03:44 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Why would you choose pine over MDF for a sub box? Just curious...
Old Aug 3, 2003 | 04:06 PM
KYL98's Avatar
Car: 1991 Z28
one reason .....weight.
Old Aug 3, 2003 | 08:16 PM
Cuno's Avatar
Pine is lighter but will also flex...not good for sound quality.
Old Aug 3, 2003 | 09:01 PM
KYL98's Avatar
Car: 1991 Z28
for the box Im building...it wont flex...there wont be over a foot of the board without a brace...so it will work fine.....Ive been building sub boxes from pine for years.....yellow pine actually...never had any problems.
Old Aug 4, 2003 | 07:10 AM
FyreLance's Avatar
So with as much bracing as you have to use would you be really saving much weight?
(Not being a jerk)
Old Aug 4, 2003 | 09:42 AM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Check manufacturer's recommendation on what size box the speaker requires. Makes a huge difference. Not all speakers require the same air volume.
Old Aug 4, 2003 | 11:13 AM
KYL98's Avatar
Car: 1991 Z28
not that much bracing....but three 12's in their own "box" will brace up the box enough it wont flex. The boxes are going to be ported....so even if they flex a little bit...its not going to hurt sound quality....Ive been building boxes for about 10yrs now....started out with the old Kicker boxes And yes I know that each speaker requires different cu ft of space...ported or sealed. Im thinking of going with three 12" JLAudio W7 or W0's(12ohms) with "about" a cubic ft per sub.....with a 2.5 in port 7in long....should tune the box to about 45hz.
Old Aug 4, 2003 | 11:50 AM
FyreLance's Avatar
... there's a BIG difference between 12w0's and 12w7's...
Old Aug 4, 2003 | 11:57 AM
KYL98's Avatar
Car: 1991 Z28
Yeah I know....price being the biggest..lol. My best friend owns a local audio shop...and we looked last nite but couldnt find out if the W7's come in 12ohm or not.....I had three 10in W0's in my 96 Z28 a long time ago.....with a Rockford Punch 700S....sounded pretty good Ill find a pic of that box and put on here....
Old Aug 4, 2003 | 01:21 PM
KYL98's Avatar
Car: 1991 Z28
Here's a few pics from my 96Z28....the amps were the original Kickers...before I got the Rockford...these pics are way old...lol
Old Aug 4, 2003 | 01:22 PM
KYL98's Avatar
Car: 1991 Z28
another...JVC head unit
KYL98's Avatar
Car: 1991 Z28
another
Old Aug 4, 2003 | 01:24 PM
KYL98's Avatar
Car: 1991 Z28
The 96 Z
Old Aug 4, 2003 | 06:55 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
jensen, jvc, sony, pine boxes... you guys crack me up. jensen sucks, thats why their amps melt down. jvc and sony also have their own workmanship problems. and pine boxes, are you kidding me? like it really matters what type of pine it is. there is a reason why all major box building companies use mdf... its alot better than other materials. particle board is even better than pine. sure you can use pine, but for it to sounds as good as mdf, it has to be about twice as thick. kinda throws the weight issue in the water, doesnt it? bracing is not gonna help it much on the flexing, unless you have a brace every about 3 inches. not very plausible if you ask me. i could get all into the physics of it with you but im not really in the mood. this post is kinda hurting my brain anyways. for ****s and giggles, ill post my box. pay no attention to the dirtyness and amps, there will be an amp rack there in a couple of days or so.
jacob
Old Aug 4, 2003 | 07:04 PM
Car: 1985 IROC Z-28
Engine: 355
Axle/Gears: 3:73
MDF is a very "sound dead " material. Doesn't transmit vibration like regular wood. That's why EVERYONE uses it.
Old Aug 4, 2003 | 09:45 PM
KYL98's Avatar
Car: 1991 Z28
Ok guys...good points. Ive always used pine in the past....never really built anything for competition or anything....but I can admit when Im wrong.....so where could I get the MDF board? Should I go with 3 10's like I had in my 96...or would two 12's get the job done....I know theres always the issue of speakers, power....etc...just wanted to get some suggestions. Ill definitely try out the MDF and see for myself. Thanks guys.
Old Aug 5, 2003 | 01:32 AM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
good man. im glad you are open minded. now to give you my suggestions. first of all, you can get mdf from home depot or lowes or some place like that. you should get 3/4" thick and a 4' x 4' sheet should be about right for a box. you may need a little more, but if you plan good, you may get away w/ it. secondly, i would go with 2 12s. many reasons why... probably be about as loud and sound cleaner, most likely cost less, easier to make a box for, and leaves more enclosure space w/ 1 less woofer choking for air.
Old Aug 5, 2003 | 07:00 AM
9177's Avatar
Its all in the install. more subs doesn't always equal louder. 1 sub in the right box vs 2 of the same in too small of a box most likely the single sub will be louder.
Old Aug 6, 2003 | 03:49 PM
KYL98's Avatar
Car: 1991 Z28
Here's what Im doing...got a couple sheets of 3/4 MDF from Home Depot....one 12" Kicker solobaric L7...and a Kicker KX800.2. The box my buddy and I figured out...using ALL of the "trunk"....should be about 2cu ft. sealed......should sound awesome. Im going with my current head unit...Alpine9807 and 4x6 Kicker's in the dash....with Boston Acoustic 6x9's. Think that will be alright?
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
wanext
Oct 6, 2015 12:18 AM
