4ohm?? 2ohm??
Old Aug 17, 2003 | 07:16 AM
Fastcam's Avatar
Car: 1986 Z28
Engine: 305 LG4
Transmission: 700 R4
4ohm?? 2ohm??
I just got new subs that say they are 4ohm. But i think my amp is only a 2 ohm will it work or do i need a new amp? Thanks!
Old Aug 17, 2003 | 08:57 AM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
It will work, but the subs will not kick as hard as using a 4ohm amp. It's always best to match the impedance, but using 4ohm subs with a 2ohm amp is quite safe. The other way round is a big no no though, for future reference.
Old Aug 17, 2003 | 02:14 PM
Fastcam's Avatar
Car: 1986 Z28
Engine: 305 LG4
Thanks!! For future reference what is a good 4 ohm amp that puts out 1200 watts?
Old Aug 17, 2003 | 02:35 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
To clear the confusion....
You can run your 4 ohm sub on your "2 ohm amp", because the 2 ohm rating is a minimum impedance that the sub can drive, safely.
Amplifiers don't have "impedance", that can drive certain loads though. Most class A/B 2 channel amps are rated to run loads from 2 ohm to 8 ohm per channel, which is 4 ohm to 16 ohm bridged, why the difference between stereo and bridged? because when you bridge an amp, each channel sees half the load, so you will most likely be running your amp at full potential anyway, this is difficult to say though, without knowing exactly what the amp is.
A mono amp that is rated to run a 2 ohm load, will only be running approximatley half the rated out put at 4 ohms, depending on design, there are some amps that have the same power output regardless of impedance, JL amps are designed this way, others may have the same output at 4 and 2 ohms, but might drop at higher impedances.
Old Aug 18, 2003 | 01:18 PM
si_camaro's Avatar
Car: 85 Z28
I think you created more confusion for the poor guy than you cleared up....
Sorry I can't name any amps for you, as the market in the US is a lot different to that of the UK and we don't have the same brands here.
Old Aug 19, 2003 | 09:19 AM
Polecat's Avatar
first and foremost question should be what woofers? Are they dual voice coil or single voice coil?
If they are two DVC 4 ohm subs, you can find monoblock amps that will power into either a 4 ohm load, or 1 ohm load. Mostly widespread is the 1 ohm load, which you will run into a list of good amplifiers.
But preferred a class D amp on subs over the older traditional A/B amp.
Dewey316
Car Audio
23
Jul 7, 2003 01:01 PM
NEEDforSPEED
Car Audio
Jun 15, 2002 08:05 PM
87transam5.7tpi
Car Audio
Jan 6, 2002 10:28 PM
TrueBlue91RS
Car Audio
Sep 30, 2001 11:35 PM
85ws6TA
Car Audio
Sep 18, 2001 06:39 PM
