Brain-fart, Need help with DVC
Old Sep 17, 2001 | 05:01 AM
85ws6TA's Avatar
Car: '92 Typhoon/ '79 Vette
Engine: Turbo 4.3L/Forged 355ci
Transmission: 4l60/th350
So im considering geting a couple 12" L7 Kickers. they have a dual 4ohm and dual 2ohm models. i have a PPI amp im going to run at 400watts X 2 @2ohm. how can i achieve this? i know with single voice coil, each sub needs to be 4ohm and you run it in parallel. so im thinking i need the dual 2ohm model.
can anyone help out?
Old Sep 17, 2001 | 08:57 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Series-wiring 2 2-ohm coils will provide the 4-ohm impedance you need for each sub.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 17, 2001 | 08:03 PM
TrueBlue91RS's Avatar
Just for curiousity's sake, how do you wire subs in series as opposed to parallel? The only subs I've ever wired have been singles.
Old Sep 17, 2001 | 09:48 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
So you are going to run these subs in stereo or mono, is first question?
Old Sep 18, 2001 | 06:39 PM
85ws6TA's Avatar
There going in mono, but my brain fart stopped. i rememberd how i have to wire it.
i have to wire the subs (2x2ohm) themselves in series, (to get 4ohm) then run them off the amp in parallel, bridged into 2ohm mono. i just had to remeber how to get each sub to run at 4ohm, which i checked out the Kicker square sub online manual and it showed exactly what i needed. thanks for the help tho.
cbarry
Car Audio
Jun 25, 2002 11:02 PM
EjBaL
Car Audio
Jun 20, 2002 11:07 PM
CD MaroMan 91
Car Audio
May 7, 2002 09:58 PM
PimpRod92RS
Car Audio
May 1, 2002 09:17 AM
DABE
Car Audio
Apr 15, 2002 10:48 PM
