wiring problem
Old Oct 8, 2003 | 07:42 PM
screamingz28's Avatar
Car: 85 Z28
Engine: 305 LB9 TPI
Transmission: TH-700R4
wiring problem
i just installed my sony explode cd player and after i programmed all of my stations in it and the time etc. i turned it off. the next day i turned it on and it remembered nothing. it does it all the time. i know i hooked up the wrong wire or a wire is missing the connection. everything runs fine except for this. i can use some help and advice.
Old Oct 8, 2003 | 10:22 PM
napalmdemos's Avatar
Car: 91 Firebird
Engine: 305 TBI
The memory wire needs to be ran to a constant source of power so it will hold all of your settings.
Old Oct 9, 2003 | 07:48 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Do what napalmdemos said. If that don't fix it let use know. Some of the Sony have a problem with this, but the first thing to do is HOOK IT UP RIGHT.
Old Oct 10, 2003 | 08:04 AM
Car: 85 Z28
Engine: 305 LB9 TPI
which one is the memory wire?
Old Oct 12, 2003 | 08:01 PM
Car: 91 Firebird
Engine: 305 TBI
The wires should be labled but if not refer to your owners manual.
They normally range from orange and yellow.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Bert87
Aug 23, 2015 03:50 PM
Fronzizzle
Aug 17, 2015 02:52 PM
