lots of power!!!
Old Oct 26, 2003 | 08:41 PM
blaze1's Avatar
Car: 1989 iroc
Engine: l98 tpi
Transmission: ????
lots of power!!!
How do i get 2ohm power out of a 4ohm sub? Any tricks or advise would help alot.
MCL Blaze
Old Oct 26, 2003 | 08:44 PM
Faded's Avatar
Car: '91 Firebird
If it's DVC, wire it + to +, - to -. If it's SVC, well, you're out of luck.
Old Oct 26, 2003 | 08:46 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Not much tricks to it. Just wiring differently. I'll hook ya up.
If it's a DVC (Dual Voice Coil) sub type it's easy. You can turn a 4 ohm into a 2 ohm. If it's a single voice coil type then you will need 2 single 4 ohms to make a 2 ohm.
1 DVC driver with Voice Coils in Parallel
Connecting the two voice coils of the driver in parallel (+ to +, - to -) will result in the following impedances:
Dual-6 Ohm Subwoofer: 3 Ohms
Dual-4 Ohm Subwoofer: 2 Ohms
Dual-2 Ohm Subwoofer: 1 Ohms
2 SVC drivers with Voice Coils in Parallel
Important: Do not implement any wiring scheme not seen here, including but not limited to series connections between drivers. For more information on why, please consult the DVC FAQ.
3 Ohm Subwoofer: 1.5 Ohms
4 Ohm Subwoofers: 2 Ohms
8 Ohm Subwoofers: 4 Ohms
12 Ohm Subwoofers: 6 Ohms
Wanna see more stuff (hooking up 1 to 6 DVCs or Singles check this out)
BRoss99
Aug 10, 2025 05:08 PM
jhawkeye
May 25, 2022 06:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
